DIY Class A/B Amp The "Wolverine" build thread
Your build looks great! Looking at the pictures of your board I am asking myself why you used the two small heatsinks but omitted the third, biggest heatsink for the driver transistors (?).
With the EF3-4 the builder have the option to mount the driver transistors on the main heatsink.
Reactions: AddiDub
Obviously, this amplifier has a great potential, but to attain such results there must be something more. Could you, please, tell us what are the most important practical details that lead to such an extraordinary result.
Hi Berlusconi,
This amplifier has been heavily optimised through simulation and measurement and then modification to achieve high performance.
If you have a look at the circuit on the first page of this thread it will give you an idea of some of the techniques involved.
- Daniel
To be honest all the hard work has been completed for us, with the tireless effort of the design team. The 1000's of hours that group put into this amplifier is what makes it perform the way it does.
All it takes in the end is to follow the build guide to the letter, ask questions if you are unsure, and match transistors/resistors that need so.
To be clear though it is not an easy task to measure this amplifier at the low levels of distortion that it produces, all I was showing was what it is capable of, and I still think it will measure lower still.
Reactions: danieljw
Indeed. I have spent lots of efforts and money to be able to measure audio equipment. And I still lag behind: yesterday I was able to measure 0,00047 THD, which is way too rough for amplifier ot this quality class. Perhaps I will invest more.
But, I still maintain that these computer-aided measurements, however rough, are of the paramount importance, not just to measure distortion but also to identify sources of noise, hum and buzz, to identify problems with wiring etc. I simply don't understand these who rely just on listening. From my experience in industrial applications I know that just equipment that measures good may work good. And Wolverine measures amasingly good.
I know that the mjl21193/94 are not recommended for this amp anymore, but can you guys measure the hfe of some of them ?
The datasheet says that the hfe for these transistors should not be more than 75 and I have a bunch of 21193 with the hfe between 90 and 103, while the 21194 will measure between 33-41.
To the Wolverine development team, et al - just ignore the Trolls, they obviously have nothing better to do than to pick holes in anything they're not involved with. We mere mortals believe you've ALL done a terrific job!
His profile shows that this particular one has left predominantly negative comments, disagreements and complaints on numerous other forums as well ....
'nuff said
Why should I measure when I can simulate? Too bad if the amp isn't further improved.
What are you even measuring?
Your post is not clear.
Unless you have the Bom you don't know what the values of key components are.
We also have highly accurate simulation models for the transistors which you will not have.
Also your simulation file looks very basic. Our simulation file takes trace capacitance and inductance into account with values that we actually tirelessly measured on a real board.
