How to - Distortion Measurements with REW
wow i have been wondering to buy signal generator and osciloscope, but it think this threas just saved my wallet. i need to buy those big power resistor for testing
anyway, i have Tascam US-322 which seems have basic requirement to do this. anyone ever used this tascam? any good result?
Do the loopback (Left output sine, right input) "self-test" and report the measurement result (spectrum with harmonic analysis) here.
I have the US 122 and it's too dirty for the best amplifiers. For ordinary tube amplifiers and speakers, its self distortion is still waay below what you'd likely measure. I can only imagine the 322 has advanced some in this regard.
hmm bad news, i bought this tascam 2nd hand item for behringer ecm8000 then switch into umik-1. never used this tascam & ecm combo anymore
anyway i will try it later, just ordered 100W dummy load resistor 4 & 8 ohm and find out how this test work.
Working with REW using the following:-
  • Focusrite Scarlett Solo
  • FiiO M7 Audio Media Player
  • Mini-itx computer with Linux
  • 1khz file copied from Audacity to the M7. The FiiO fixed line output is 2v p-p
Photos attached. Next will be working on DIY 1khz generator
Q1: What can be done about the strong 3rd harmonic from a Wien/Lamp 1khz oscillator. I was thinking about using 1/2 LM4562 as some kind of filter.
Q2: What connections are needed to loopback the SOLO for calibration.
Have you tried the REW generator? It's very good. I have an Akitika 1KHz generator but hardly ever use it. I have the Scarlett Solo too. Just be sure to calibrate the REW generator before using. I use a 60 Hz sine wave for calibration since that's the most accurate frequency for my DMM.
The Akitika seems to be the best but I am working on an interesting DIY 1Khz. That is why I ask questions here.
Joined 2014
I am currently measuring both a Victor and an Akitika 1 kHz oscillator using REW and a COSMOS APU 1kHz notch with the a calibration file applied in REW under microphone calibrations. I am reading -110dB for a 2nd harmonic with +6dB switch engaged and -104dB with 0dB switch engaged. BTW, I'm using a Focusrite Solo for my ADC. I thought with the compensation file, that REW would read direct. However if I subtract the 30dB of the notch from the reading, I get something closer to what it should be reading. Any ideas what checkbox I've left unchecked?
Here's a screen grab of a Nad 3020's distortion at full power before recap. Feeding a Motu M2 via Autoranger outputting 500mv and victors Oscillator. Seems pretty close to spec still. Any thoughts?
hi, need some help
what kind of windowing should be used to get closer to real THD+n distortion numbers?
depending on windowing i get ~123dB THD+N (Blackman-Harris 7; oh wow great... but probably not true :) ) or ~113dB (Hann). probably the latter value is the real one (or closer to).
my setup is SMSL Su-9n + Cosmos ADC in MONO
Cosmos ADC set @4.7Vrms input; input impedance 1.7kOhm (Hot - GND); SMSL output voltage 3.15Vrms between Hot-Cold pin
  • pomiary SMSL testy kabli.mdat
Founder of XSA-Labs
Joined 2012
I always use BH7. Just take note of the settings - and a good way is to show the settings dialog box on your screenshots so we know how much averaging, etc. The SU-9n is one of the best DACs out there and should probably best your ADC. You should also use a very low distortion 1kHz oscillator like Viktor’s source. -123dB is not unreasonable from SU-9n.
I have started to show this dialog on the upper right of my FFTs.
Reactions: 1 user
