Aleph J illustrated build guide
I'm curious what a needle-pin is as a connection. Could someone share a picture?
I used a lot of fast-on connections in my builds. Bought lots of crimp-on connectors in various sizes (20awg, 16awg, etc.) from Amazon
Thank you.
looks like some are soldered fast-ons and some are wires soldered into the board.
Do some have a physical pin in them?
I used a Mogami W3101 4mm² (#12AWG) cable and heavy-duty pure copper Terminals PIN WIRE 16-14AWG (Mouser):
https://au.mouser.com/ProductDetail/TE-Connectivity/165045?qs=HjC056NR38F9ygYZj8ieGw==&countrycode=AU&currencycode=AUD
Check the picture I attached. That 4mm² (#12AWG) wire can almost fit... the remainder can be carefully spread on top of the pins and then soldered. You'll need a 60 - 80W soldering iron.
Thank you.
Yes, it looks that way but is not. I used pins looking like the ones MZM posted, but without isulation. First presoldered the wires, then machanically shrinked the needle pins, then solder it all together with a bunch of flux and a huge solder tip. Then soldered that to the board. So four processes. Not going anywhere :rofl:
I had all the bits to make an AJ, was waiting for the DIYaudio Store to get some boards in and got bored. So I looked at some layouts, learnt KiCAD and got a few PCB’s made in china. Just finished stuffing my first board and hopefully get the second done tomorrow. I still need to sort out my heatsinks and power supply. Should have magic smoke or an amp in a couple of weeks. Never made an amp from scratch so fingers crossed
I had all the bits to make an AJ, was waiting for the DIYaudio Store to get some boards in and got bored. So I looked at some layouts, learnt KiCAD and got a few PCB’s made in china. Just finished stuffing my first board and hopefully get the second done tomorrow. I still need to sort out my heatsinks and power supply. Should have magic smoke or an amp in a couple of weeks. Never made an amp from scratch so fingers crossed View attachment 1082788
Sweet!!🙂
I really like the placement of the placement of the +/- 24V solder points. The heart rate monitor is a added bonus cool touch 😎👍
