Yes, I have an homage to LS3/5A using modern drivers and an updated XO that replicates the step response and freq response of LS3/5A. More info here.LS3/5a clone yeah?
They turned out really well - super sounding and have been built by about half a dozen other members whom all like it.
https://www.diyaudio.com/community/threads/rst28f-and-dc130a-foamcore-homage-to-ls3-5a.359176/
Stained BB ply cabinet with a matte finish baffle:
Only issue is the depth is a bit much for my space. I did see those and they look greatI would suggest PuriBliss or PuriWave, they both look well designed, measurements are available.
https://hificompass.com/en/projects/2-way-systems
You know as long as you keep the original driver positions relative to the top and side edges of the front baffle the same, you can reduce the depth of the box and increase the height from the bottom of the speaker to get the same original volume.
I just finished a set of piccolos as well. They ended up in a slightly larger box (~9.5 L vs 7.5 L in Jeff's original design), and the tuning as a result is flatter than the original.
I am very pleased with the sound of these little speakers, definitely a great bang for buck compact solution i would recommend. I cannot compare with Jeff's own box alignment, but the bass is very full and goes deep (the Fb is a bit lower than the 7.5 L box). I have not had a great deal of time listening to these so at the moment i can just say that plugging them in for the first time was a very pleasant surprise, and i had not expected such full bass from them. My impression is also that the integration between the drivers works really well, and not something i notice.
I also happen to own a pair of bookshelf Alpair 10.3s. These are in 14L bass reflex boxes (originally used for 10ps), but the tuning was adjusted to suit the metal cone drivers. They are great sounding speakers that i have used happily for many years. They became my secondary set of speakers after i put the 10ps in Pensil cabinets, but they deliver a lovely detailed and full music experience. I cannot say i notice a great deal of difference in the top end between these full-rangers and the two-ways with actual tweeters so far, but that is going to differ from person to person. Suffice to say i would also not hesitate to recommend these speakers, and as Dave said, optimal box is around 10L so comes to much the same size as the piccolos. I have heard from others that full-rangers don't do all genres of music well, so that's another consideration, but for my needs they have been great speakers that i have and still do enjoy.
Just another 5c.
Just another 5c.
Does that also mean the original crossover is still perfectly matched or does it throw some aspects slightly off?You know as long as you keep the original driver positions relative to the top and side edges of the front baffle the same, you can reduce the depth of the box and increase the height from the bottom of the speaker to get the same original volume.
Glad to see another Piccolo fan here. As I have posted in several threads, I think these relatively small speakers punch way above their size and cost. Particularly at the high end where the SBA tweeter excels.I just finished a set of piccolos as well. They ended up in a slightly larger box (~9.5 L vs 7.5 L in Jeff's original design), and the tuning as a result is flatter than the original.
Just another 5c.
It may not matter much for popular music, but for classical music with lots of violins, flutes, and of course, piccolos, the high end to me is magic.
And that also goes for pianos. Part of what makes these so sound good for pianos is their ability to sustain individual piano notes. Just like you are in the room with piano yourself. Of course, that depends on the recording as well. But if it is in the recording, these speakers will deliciously reproduce it.
Original XO should work fine. Tweeter frequency response change will be minimal; changes will be more to the woofer response, but minimal.Does that also mean the original crossover is still perfectly matched or does it throw some aspects slightly off?
You can use The Edge to predict changes; I'm not an expert in using it - I'll see if I can spend some time learning it to quantify my statements.
OK I think I done this right - I put the Sopranos' baffle and 4" midwoofer into the Edge (curve1 green) then just doubled the height of it (curve 2 red) but keep the width the same. This would give a silly looking speaker but as you can see, even in that example, the diffraction difference cause by increasing the height is negligible.
Now I have to go back and look at every sealed or front ported speaker that was too deep and think of how it would look in taller format!
Another question I guess. If something was rear ported, would porting it out the front instead change much?
If you're going to put them right up against the wall, go sealed and get a sub, IMO.
If you're going to put them less than half a foot away, then it would be preferable to go front-ported, depending on what the tuning frequency is.
If they will have a foot or so, then it won't make much difference.
If I go back to my earlier recommendation for Goran's Classic, we have a 27L cabinet with front baffle of 40cm H x 26cm W, therefore original depth is 26cm.
If your depth constraint is 25cm, then you just need to increase the height below the woofer by 1-2cm and keep everything else the same so 41-42cm H x 26cm W x 25cm D - pretty easy.
Goran had also modeled a closed box where ported F6 = 32hz, sealed F6 = 45hz - not bad at all!
I just approximated the visual difference quickly -- looks fine.
Nice. Looking through his stuff now. Does he have designs using the higher end Illuminator drivers? (Those the top scan speak models?)If you're going to put them right up against the wall, go sealed and get a sub, IMO.
Ellipticor is their top range now 🤣
Just look yourself through his website. He doesn't seem to have an Illu design but does have some Revelator + AudioTechnology ($$$$) designs.
is there any pic for second trick?In my experience English full-range drivers often have a taller peak ~5-8khz than vintage German ones, but it is a common problem. I consider my one vintage Wharfedale 8", old Lowther PM6A (rolled whizzer), and new Michael's/Hifi-Bird/Isred ("drum paper") all to be ear-bleeding on-axis. The PM6A facing upward with a makeshift 360-degree omnidirectional reflector (after Harman Kardon X 360 which used custom PM6) still sounded piercing and unrealistic. HOWEVER, this peak helps to give them a very palpable dynamic realism that is missing from more "correct" speakers. Listening off-axis (possibly the old English way??) is not a solution because >10khz then vanish killing precise imaging and air (of course vintage predates stereo). So what to do? I have two work-arounds. One is to find complementary drivers when stacked neutralize the individual driver's shortcomings, 1+1 > 2. The soundstage thus obtained is more like musicians are present life in the room, which works well for smaller ensemble music. The other trick is to apply a simple 1st-order notch filter as if the full-range driver were two drivers, one LP (inductor) and the other HP (capacitor) in parallel into the driver's +. The 1st-order XO math works very well in predicting the notch; should a sharp valley results, resistors can be parallelled to fill it. This sounds complicated but really isn't! (Q: what happens to phase?)
Note: 1st-order LP -3dB@f1=160hz*ohm/mH, HP -3dB@f2=160khz/ohm/uF, slope -6dB/octave i.e. halved, notch at their geometric mean sqrt(f1*f2). 1st-order XO is simply f1=f2.
If you mean the notch filter, there isn't much to see, just inductor parallels capacitor, both connecting amp + with driver +. Here's a summary of my minimalist methods https://www.diyaudio.com/community/...nge-drivers-and-a-tweeter.391053/post-7143129is there any pic for second trick?
An interesting observation is that, regardless of the actual impedance Z, the notch center frequency is fixed because both LPF and HPF will move linearly (if higher Z) toward or (if lower Z) away from each other, only affecting the depth of the notch -- which if needed could be filled in with a resistor-chain.
Before I had this "figured out", I had seen some mention of Mr Pass's filter for the Lowther PM6A, but later when I tried to find the filter I couldn't. This page 1/3 down has pics https://homeaudio.jimdofree.com/
Hi, having not found the MTM Sopranos crossover schematic on the internet, I kindly ask if any of you can help me where to find it. Regards Gilardi
It's proprietary to Meniscus Audio Group, so you won't find it.
Sadly, Meniscus will slowly be closing up shop. Their website says more....
That is a pity. How recognizable is the remark about stuff harder to get your hands on. This seems to be a constant challenge through the years. Probably because it’s a small community, us DIY audio folks.
What sad news! What will happen to Jeff Babgy's designs done for them? Will they become unobtainable?
They are working on possibly continuing those in some way, at least for a little while. How and in what capacity I don't know.
Hi, actually I was looking for the design of the crossover because I wanted to build myself an MTM center speaker with two SB12NRX25-4 in series + one SB26STCN-04 tweeter.
PS I don't have a program to do it, I only have bassbox 6 pro. If you want to help me I will be grateful. Thanks in advance
- Compact Bookshelf Build - Options / Recommendations
