Best cabinet plans for Markaudio Pluvia7HD
Pensil cab finished it looks great 😉 now just need to tolex it or put duratex or something similar 😉
Reactions: LeifB60
The Pencil cabinets look very good.
I tried laminating a test XPS cabinet with vinyl peel&stick wood-look flooring strips. Not recommended. Someone with actual skills could probably make it work. There is probably a similar grain and color to match.
FYI/FWIW/YMMV: I quickly gave up on any kind of veneering, so the majority of the DIY consumer speakers, bookcases, coffee, end tables, etc., I was involved with way back when were wallpapered with thick textured wallpaper to deal with the typically less than perfect joints, etc., with good enough results on all getting good marks for fooling folks, especially the Ga. Marble architectural, column/tower (MLTL) speakers where only the top was marble (for mass loading).
It should be VERY well teased and it will hold itself in place. It takes significant time to properly tease, don’t short course;f on this criticsl step.
Typically people seem to end up with about 2/3rds what is specified. The back is removable so that damping can be adjusted to room, placement, taste, and the amp used to drive them
Before and after (40g acoustistuff)
dave
Reactions: GM and LeifB60
Some people claim that polyfill doesnt do anything tho
It is the case that different polyfills have different character, but make no difference? Either wrong amount of not phluffed up (happens often). I tend to use acoustistuff…
Any quarter-wve line needs to have at least some of the ripple reduced (unwanted harmonics). Stuffing has been the number 1 tool, but more recently discovered tools like mass-loading and driver offset now make the calculaus more complicated.
dave
Reactions: LeifB60
dave
Have not seen Scottmoose lately. Has he vaccination?
