What other MOSFETs would be a drop in replacement for the 9520/520? I have some 2SK2013/2SJ313 I'm tempted to try, but they're so scarce now.
Confirmation means that the 2nd harmonic has negative phase. You might want to take a listen before next step.
Of course Harris p ch parts will largely fix this if you think it's a problem.
Finally getting around to getting parts for my Almost Clone board (Thanks Kevin and Mark!). DIY Audio Store has some Harris Mosfets in their F-4/BA-3 kit. They are Harris IRFP9141 (and I assume the complementary IRFP141). Perhaps overkill, but the store matches them, so it seems like a preferable source to Rochester and their burdensome minimum order. My question for the experts here is this a viable alternative to the IRF9520/520 semis in the original kits? Yes they're TO247 vs TO220 so I'd have to trim/squeeze the legs to get them to fit the board. Anything else I'm missing?
@pfdavid
I have you down for 2 boards + MOSFETs. All boards (except the first one to Franz) shipped with output transistors. You better check your package.
Yup, found them, right where you said they'd be. Sheesh! Sorry to bother the list. At least the shop got a bit cleaned up!@pfdavid
Good one. No I haven't had time to sit down and give the amp with the Vishay's a listen. Maybe tonight.
I have a bunch of matched pairs of the Vishays if anyone wants to try them.
Are there any round boards for sale? Sorry if my question is so out of place as I am getting sloppy with following all the threads here lately.@pfdavid
I think you may be talking about ACA Redux?Are there any round boards for sale? Sorry if my question is so out of place as I am getting sloppy with following all the threads here lately.
Ops, you tight! Mini is the new one from the latest virtual burning amp, right? I’d take that as well haha 🙂
Can you quantify soon in terms of days or hours?The ACA Mini should be in the store SOON! 📦
- DIY ACA mini
