DAC AD1862: Almost THT, I2S input, NOS, R-2R
I will be happy if anyone could give up to me their bad TDA1541 S2 in spite of trashing them.... please !🥷
I can offer for ears refurbishment a cd, you choose: Madona or Killy Minog. Bargain, do not loose this opportunity.
I need to sell all the devices I have to buy a one from New old stock made in Made in Holland ... and probably a house too ...😀
Reactions: diyiggy
Have the 1701, further iteration not through hole but pins compatible iirc. Below the AD1862, TDA1541A, TDA1540, AD1865, PCM56/58... subjective of course and as far not tested in iso layout, who knows ?
1862 and 63 are the best dac in audio. Also there is D20400 (ultra analog). 1702/04 going after them. That's all the multibit Dac. As for multibit delta sigma - maybe AK4497/90 and of course PCM1794/92 is best.
Reactions: mikorist
You read it but did you test it ?
I did, there is a great diffetence between believing to know and knowing for true.
... and I know from reality you forgot the two first of the school which is a Philips and I would put the pcm56 and his brother in front of the pcm17xx with which I would not waste time.
I do prefer ad1862 to pcm63 but thanks to miro you can test both at very near iso conf (near pcbs) using same parts and supply but the dac chip...
YMMV of course, but having hearing them in old school machines does not suffice to get an idea. And of course the pcm1792 etc even does not touch the 4 first of my list...
If Miro1360 worked mainly on the ad1862 it is not by chance...one should has it as TDA1541A(s)
Here is the schematic of our PCM63P DAC 🤓
