Universal PCB for Purifi 1ET400A amps
Why lamps in anything then? Class D ain't just for low distorsion, it heats way less, takes way less space, and with tubes you get that nice well known sound signature.
Why not just use dsp to add distortion? No heat and the ability it tailor it exactly how one wants it. Seems like ordering a $200 aged wagyu steak and covering it with A-1 steak sauce.
You do realize that world doesn't revolve around you? You are entitled to your opinion, to your own subjective feelings of everything around you. But not everyone is you, in fact, no one is you but you. There are so much different tastes out there, and so many different people, hell, people like pineapple over pizza, i myself don't like it, but i damn love that it exists cuz my friend likes it. But getting back to, class d is perfect for coloration, it is a blank slate sort of, so you can adjust your system if you like syrup or you can leave it as it is better than with any device put there. This right here is syrup, and a lot of people love syrup 🙂
Don't believe I was doing anything other than pointing out a more efficient method of adding dirt to clean water. I was stating my opinion, thanks for recognizing my right to do so. I accept your right to like dirty water- which is why I pointed out the dsp route. Enjoy!
I honestly wasn't trying to be rude. English isn't my primary language so i basically translate in my head 😁 Exactly, there are numerous ways. I liked how nutube "muddies" my water 😅 This seems as an interesting project as well. If there is a rev that adds volume control to this buffer, i might give it a go due to tube rolling.
Just tested the second channel.
Do you have any recommendations for DSP to recreate tube sound? I haven't heard any that I enjoyed.
Funny though, how one person can love a fillet and I wouldn't be seen dead ordering one. A ribeye for me.
This is exactly what makes the Purifi so great for my use cases and why they're my favourite amps at the moment. I need 150w+ for my speakers and I won't be building a 1000V+ Set AMP that weighs 100kg and could be used to heat the town. Although I do own a PSE 6c33c that does put out 45w and sounds great, but too dangerous with kids. Much cheaper and efficient to use a Purifi as buffer, driven by a multitude of pre-amp that are often far less expensive than an amplifier build. One day you can listen to a massive sounding DHT amp (300b,10y etc tube pre), next day an IDHT, then a simple single ended class A design with again big power and even throw in a discrete class A pre. Choose whatever suits your music taste.
I much prefer my tube pre-amp in front of the purifi amp's than without, but that's what suits my room/music tastes etc
@Koifarm - I have a couple of projects under the way, but I will certainly be trying your design. Thank you for releasing it to the public at no cost!
You do need a separate power supply for the tube stage. For a lot of people this is very important so they can choose between linear or smps supply.
No, it has other pinout and different specs. But it is possible to design a mu follower with the 5687.
Here the PCB, gerber files and schematic for the 5687 tube.
6 Resistors have a other value to meet the 5687 spec.
R4,R7,R14,R17 changed from 150 to 120 and R5,R15 changed from 5k6 to 4k7 3Watt.
  • Gerber 5687 Tube preamp for 1et400a or NC500 .zip
Reactions: _henry_
Koifarm,
I see from your PIC that you are getting close to being able to start your subjective listening tests.
Is there are reason beyond offering options that you offered up a version that uses 5687 tubes?
Incidentally I am still looking for a good source to buy a few JST B06P-VL PCB connectors. Everybody that I have contacted here in the states has zero inventory
