You could also try 100pF C2Y or no C2Y before VTA experimentation. To can decide which approach is more consistent with your different records. It's easy because there are female pin sockets for that treble trim cap.Now high end is sounding hotter with Steve Winwoods "Live from the Canteen", not as heavy vinyl as the Jah Wobble album is, so probably shifted VTA a smidge. A bit more tail up could be in order.
Russellc
Oh, I didn't know you could run it with no cap at all. Even though I was gone all day and didnt get to play it more until now, I had it cooking.
Should be getting settled in I guess. will play more albums to get a feel for it before altering loading caps.
Bubba
Bubba
The main treble eq cap of the riaa filter is C2 15nF. C2Y is a parallel trim. Usually 220pF. Bringing the total value to about 15n2. Which is popular. But with very smooth carts it can be tried in less pF or even skipped. That's making the curve brighter. For trebly carts >220pF C2Y can also be tried.
Thanks for the info, of course like most changes, I assume powered down! Will the cap change alter and require tweek of TP? I guess I will know soon enough.
Russellc
Russellc
Hmmm. No cap sounds pretty good! Like you said, TP remained stable. Yup, no cap seems to have peeled the right banana. Shazam.
Russellc
Russellc
Oh yes. Amazing what removing the cap did. Will try other caps you said to try as well, but this with a little VTA tweek may be it.
Good to know. That is exactly the reason why there is C2Y flexibility in the design. To aid system synergy. No matter if using 220pF has been reported correctly balanced by the great majority of builders, some cases needing to tweak the treble curve little differently will certainly appear.
I also experimented with different type of caps for C2Y. Although I now have polystyrenes in my UFSP, I have tested silver micas in my FSP and liked it better.
Yes the quality of C2Y cap has some interest. Film & foil polypropylene is in the middle of those two you mentioned.
I don't know if they gonna make any difference for C2 (Wimas FKP2 - Film Foil PP), against plain Metalized PP (Epcos MKP1837) which I have in place right now. I think these things should be done as last touches to tailor your system.Yes the quality of C2Y cap has some interest. Film & foil polypropylene is in the middle of those two you mentioned.
Yes, and I am still adapting to it as well. but midrange clarity took a big jump when I pulled the cap. While it changes, right now it is working with a DIY Pass BA 2018 line stage and my DIY Aleph J power amp. Speaker right now are Tekton Enzo.Good to know. That is exactly the reason why there is C2Y flexibility in the design. To aid system synergy. No matter if using 220pF has been reported correctly balanced by the great majority of builders, some cases needing to tweak the treble curve little differently will certainly appear.
Russellc
The SAE cart probably appreciates the bit livelier curve indeed. Its been described as euphonic by some: https://www.vinylengine.com/turntable_forum/viewtopic.php?t=60415
I had it for quite a bit and used it with FSP. More details and neutral sound than DL103. I don't know if I could say it had 'live sound' but it certainly didn't sound relaxed. It needed many hours to sound right (bought NOS). Anyway good all-round sound for it's money.The SAE cart probably appreciates the bit livelier curve indeed. https://www.vinylengine.com/turntable_forum/viewtopic.php?t=60415
Yes, I believe it is 2.5 on the output? I believe that was it high output moving coil. A few years ago a boatload of them NOS came on the market. At that time there was another version, but only a stylus change (eliptical) and I wanted the "Line trace" or whatever version. I've got its paperwork around here somewhere or the other, but pretty sure output is 2.5.Maybe you had the MC model? The 1000LT is HMC.
Just switched back to the 220 cap....it sounds pretty good now too! Clearly I need more time to familiarize myself with this thing.
Quite favorable so far, very nice. I have a new cart in my future, either Hana or Audio Tech, low out put.
Maybe the 150 cap, trying it now.
Russellc
Also as to the high frequency, my ears are 66 years old and preamp is driving about 20ft of interconnect cable.
Russellc
Russellc
In the day they were expensive. The NOS I got for 199.00 IIRC, and snagged a Shure V15 vxmr for the same price, and spare stylus pile at the same time. I'm familiar with this cartridge, Ive been using it with DIY Pearl 2 since I bought itI had it for quite a bit and used it with FSP. More details and neutral sound than DL103. I don't know if I could say it had 'live sound' but it certainly didn't sound relaxed. It needed many hours to sound right (bought NOS). Anyway good all-round sound for it's money.
- Analogue Source
- Simplistic NJFET RIAA
