YupThe line preamp drives 20ft of cable?
Wima FKP2 I would say. This one has 2.5% tolerance. Mouser has stock. Manufacturer# FKP2D001001D00HSSDI will have to get a pair. Is there a suggested part I could order from one of the suppliers?
Russellc
Or removing and inserting the caps back in the sockets worked some oxides away from the pinsJust switched back to the 220 cap....it sounds pretty good now too! Clearly I need more time to familiarize myself with this thing.
That's possible, or even inside the socket I guess. Since it wasnt going to be soldered, I didnt prep it to solder, looked shiny, so I never thought to clean it.Or removing and inserting the caps back in the sockets worked some oxides away from the pins
Russellc
I also figure that the new cartridge will yield more, obviously this SAE, while sounding fine given cost, is what it is and isnt what it isnt.
Either the AT33EV or Hana should perform substantially better. The AT looks like the most go for the least dough, but the Hana reviews sound like I may like it better higher cost not withstanding. AT is a bargain. I'm just afraid I might want something warmer, based only on reading, not listening....
Russellc
Russellc
I spray tube op-amp and cap pins, those meant for sockets, with Deoxit when I remember.That's possible, or even inside the socket I guess. Since it wasnt going to be soldered, I didnt prep it to solder, looked shiny, so I never thought to clean it.
Russellc
Same here. I keep coming back to DL103 while tempting to go to something more neutral, like AT33, still at the end I have a suspicion that I'm go back to something more warmer. Something like an MM Nagaoka. If I get to hear a Hana I might put it on my list but reading for it hasn't convinced me yet.
Yes, reading about cartridges is fine, but its a bit like learning to swim by watching others. At some point, I have to jump in and start splashing around! I figure if its popular, at least there is a market if it sucks. These cartridges have been used by several here, so at least that is an opinion using this phono pre, that is a help. All is some compromise
Russellc
Russellc
I remember when I built the DIY Pearl 2, several of us had purchased the SAE cartridges and all had a bizzare noise problemThe line preamp drives 20ft of cable?
that was traced to that cartridge needing a cap/resistor from output signal to ground. If I remember right, it was something about the cartridges inductance maybe? This phono is quiet as it can be, so I doubt it, but just thought I would mention that.
Russellc
I dont think this has any issue like that, I just know there is something a little odd about what it presents to the preamp. The thread is in 6L6 Pearl 2 build thread on the Pass forum. I will locate it. This unit sounds excellent, Im just gilding lilies and making a silk purse out a SAE! It actually sounds fine, I just know much better this pre will sound with a better cartridge. ( and of course, more$$$)
Russellc
Russellc
I also have a DL-103R. Vintage type carts that have a strong following. Medium resolution, exaggerated presence range. You would like best a limited edition DL-103SA I would think. Better body resonance control, more & smoother detail. Generally sold out, Thakker used to offer it at EUR 699. Transplanting a DL-103R into a hardwood body should be the equivalent. The DL-103 family appreciates heavy arms and classic cuts.Same here. I keep coming back to DL103 while tempting to go to something more neutral, like AT33, still at the end I have a suspicion that I'm go back to something more warmer. Something like an MM Nagaoka. If I get to hear a Hana I might put it on my list but reading for it hasn't convinced me yet.
Thanks Nick, DL103SA as well the more expensive DL-S1 have been suggested to me. When finance permits I will buy the ticket and take the trip. I tend to give more importance to tonearm and phono stage than cartridges which I use to give the flavor I want to my system.
I don't know if I am adjusting to this phono, it's breaking in or what, but it is sounding better and better. Perhaps the cartridge is loosening up from increased recent use, but this thing is coming into its own. Dead silent.
IIn the beginning I heard a very live mid presence region, highs a bit recessed, a slight boominess with bass, and a bit of congestion.
I really can't say this was the phono or ancillaries causing this but after playing with caps, VTA etc. and considerable play it is sounding fantastic.
Thanks Salas!
Russellc
Thanks Salas!
Russellc
- Analogue Source
- Simplistic NJFET RIAA
