Easy DIY tube amp
I usually prefer fixed bias, but when I do cathode bias, I use Allen Wright Vacuumstate's trick with the cathodes:
Use individual cathode resistors to ground, then connect the cathode bypass capacitors together and then ground through a single resistor of around 14% of the value of the single cathode resistor. This will reduce IMD and 3rd harmonic as well (there are some tests performed on this forum).
The connection of the 6.3V center tap depends on the rest of the circuit, voltages, and the filaments that use them,
versus the voltages on the cathodes.
Examples just for conceptual illustration:
1. All cathodes DC voltage less than 50V.
Ground the center tap (unless the filament to cathode voltage rating for the tube is very low).
2. Some of the cathodes DC Voltage is more than 100V (and the tube filament to cathode voltage rating is 100V or less).
A concertina phase splitter can have an elevated cathode, and so elevate the center tap too.
3. If the signal swings cause the cathode to rise far above its quiescent voltage, then more accurate inspection of the tube filament to cathode voltage specs, and the peak voltage of the cathode needs to be accounted for.
I am not sure I asked my question right.
Unlike the posted schematics, the transformer I will use for the SPP has a 6.3V secondary with a center tap.
Do I need to connect this CT to GND or do I leave it flapping in the breeze?
BTW I checked a bunch of old Mullard schematics and all connect this CT to GND.
Just beeing careful with my first tube build...
If you build an SPP on the Tubelab board one side of the 6.3 volt will be connected to the junction of the 30K and 150K resistors mounted on the board. In that case if your transformer has a centre tap on the 6.3 volt winding just insulate it. If you are building point to point or turret boards or similar you may connect the centre tap to the junction of the resistors.
S.
There's no practical advantage to using the C.T. as far as I know.
Want a quiet (low hum) SPP?
-Don't use a cramped chassis.
-Keep the P.T. as far away from the OPTs as much as possible.
-Position the OPTs at right angles to the P.T.
-Use a choke in the power supply and keep it at right angles to the P.T. and a few inches away.
Both of my SPP builds were so quiet they could be used to drive 100dB horns if I'd wanted.
Steve,
My OPTs are toroids, not sure how to calculate a right angle between them and the PT 🤓 .
The choke is already here as well as most of the components; I noticed a dedicated L1 choke connector on the board.
If it works as expected, I am planning a 2U 19'' chassis with all transformers inside.
I will only do the CT mod if I'm not pleased with the plain vanilla build.
Pics of my two SPP builds.
Not sure what rules apply to toroids. Looking at the amp on the right side in the attached picture it might be better to rotate the power trans 90 degrees from what is shown if using this layout with toroid OPTs.
S.
This what George wrote in post no. 23:
I disagree with reducing the value of R3. The older 12AT7's have a H-K breakdown voltage spec of 90 volts. The cathode of the second section can be nearly 90 volts depending on the B+ being used. The cathode of the first section is near ground potential. The heaters need to be biased up to somewhere between zero and the cathode voltage on pin 3 of the 12AT7. Ideally this should be about halfway between the two voltages, but some old tubes seem to exhibit hum of the voltage is too high. 30K was the best compromise in my testing many years ago with lots of different 12AT7's and 6201's. 10K might be fine with a mil spec 12AT7WA or other new production tube though.
Hi everyone, I need some more specs for my output transformers from toroidy. I told them push pull but I guess they missed that part.
This is the message I received:
I need additional information for output transformer:
1) Expected supply voltage of the system.
2) Maximum anode current
3) Amplifier power
4) Input impedance Ra (for SE) or Raa (anode - anode for PP)
5) Output impedance (4 Ohm / 8 Ohm or others)
6) System type - PP or SE
7) UL taps - what%
What I think I have so far:
1) 120v
2) ?
3) ?
4) Raa?
- I specified primary impedance: 7.6k ohm, is this different?
5) 8 for 8 ohm speakers?
6) PP
7) I plan on using UL mode mostly or only so what % should I go with?
Thanks for you guys' help.
Also, off topic but I'm also getting a PT for my little bear t11 and I'm having trouble figuring out the current rating for the 200-0-200v winding. I'll be running (3) 12ax7's and a 6c4p-ev.
