B1 with Korg Triode
Yes fairchild from the kit and I put some reference voltage.
Still checking
Yes same results. I removed it and replace by another one (1N4739A 9.1V / 1W) and it doesn’t change - still 0.2mV at T4.
As mentioned I used to have 9.1V when all parts where removed (steps 41, 42 and 43 in the guide. All voltages where correct).
Today I upgraded the B1K PSU.
The external 24V PSU is LM317 based, built on perf board with lots of pre-filtering. I also added a half wave rectifier/regulator PSU PCB left over from another project for 12V/-12V for a Muse volume control (when I get around to ordering/installing!).
Still have T7/T8 at 9.5V. Haven’t got around to experimenting yet. Listening to the new RHCP album now and it sounds VERY good!
Reactions: ffarges
well, talk to me about that
wearing spectacles from my tender age of 15
now, one for general driving and looking at bright side of life, second ones for PC work and looking at bright side of life, third ones for work and reading and looking at bright side of life, and in most cases when working having 2x lens head thingie
good thing is that I'm not much blinder than I was Kiddo, bad thing is that eyeballs are getting elasticity of pool balls
:rofl:
moral of the story - use DMM instead of:
- memory,
-brain,
-eyesight,
-Guru advice,
-etc.
Reactions: jcon2 and ffarges
I have 4 also. Pretty much the same thing.
:snail:
Reactions: ffarges
Just wanted to say I have now read all 375 pages of this thread 😵😱
Still loving my B1K with upgraded coupling caps, increased capacitance in the onboard PS caps, a few "nicer" signal path resistors, shielded wire, and linear PS (though I may "upgrade" the perfboard LM317 setup to PCB based shunt regulator down the road).
If I had to do the build again after knowing what I know and reading this entire thread I'd:
  • float the 270R resistor (maybe even make it 5W)
  • make the 10K trimmers multi turn. The stock single turn trim pots are rather sensitive
Still plan to upgrade the stock pot to an Academy Audio Muse volume control, really curious how that changes the sound. Also need to play around with bias, still sitting pretty at 9.5V
