The most important thing is that they are fitted into each other.It is strange my MAOP have totally different data, Qts is lower 0.28 and Fs is lower 34A, 35B Hz.
Do not hang on to the fact that they differ in pairs.
When did you buy them?I would like to mentioned compare to other member in forum my have low FS 34 compare to others around 41
My pair have fs 43Hz
Just as well they come in matched pairs 😀 have also noticed some pairs with 87.5 db sensitivity while mine are closer to 90db . perhaps the hand made nature of the drivers creates such differences or maybe it’s a normal variation for speakers in general but highlighted by having individual measured units .
June 2020When did you buy them?
Maybe you paid more then I.June 2020
Maybe yours is better.
But I love mine. Realy pinpoint between speakers and give me a deep soundstage.
I suppose it will go realy deep. Do you like the sound?Something between ML-TL and bass reflex my own design.
Surprisingly, I have my MAOP 10 on a FHXL being driven well by a SET EL84 tube amp at 3-4 watts per channelIt is end game for me. (RPI4-SPDIF output-SPDIF XLO Reference cable-Musician Pegasus-Hegel H200-MAOP) Only would like to try in future single ended A class integrated amplifier.
Good choice. I think they go very deep in the base.Surprisingly, I have my MAOP 10 on a FHXL being driven well by a SET EL84 tube amp at 3-4 watts per channel
Dave hello, but the Pensil cabinet design for the Alpair 10.2 can be good for the MAOP 10.2?No. Except for things like FHXL.
dave
The FHXL is, probably, a more difficult build for me.
Sincerely
Tommaso
The A10.2 MAOP should work in the A10.3 Pensil. http://frugal-phile.com/boxlib/pensils/Pensil103-plan-300114.pdf
Scott?
Original A10 MAOP would go in A10.2 Pensil.
dave
Scott?
dave
Yes it does. You can adjust the stuffing below the driver in an FHXL cabinet to suit the bass you wantGood choice. I think they go very deep in the base.
Dave is right. I originally had the A10.3 with FHXL and just swap the MAOP10 and I liked the change in driver while maintaining the FHXL cabinetWhen building cabinet(s) for the MAOP 10.2, will it typically follow the design/dimensions/displacement for Alpair 10.3, 10.2, or another model?
- Full Range
- Alpair MAOP 10.2
