Yes. The MAOP10 gives better bassPerfect. Do you like the sound?
Yes indeed. I like the sound very much.Yes. The MAOP10 gives better bass
Thanks Dave, I will have a look at the Pensil A10.3 drawing than!The A10.2 MAOP should work in the A10.3 Pensil. http://frugal-phile.com/boxlib/pensils/Pensil103-plan-300114.pdf
Scott?
Original A10 MAOP would go in A10.2 Pensil.
dave
Thanks Dave and Scott.The A10.2 MAOP should work in the A10.3 Pensil. http://frugal-phile.com/boxlib/pensils/Pensil103-plan-300114.pdf
Scott?
dave
Yes that was what I was thinking, but I'm willing to spice things up, since I have already heard MarkAudio's with bookshelf, pensil/fhxl, so trying out a WAW setup would be an interesting project.Go for it. The only big downside is more budget, for woofers, XOs. Have a spare amp in the closet?
dave
Okay thanks. The MAOPs probably have the bezel glued in also. Probably for the bigger sized drivers (extra frame stiffener)Some of th ebig drivers have the decorative bezel covers glued on at teh factory (A12p).
dave
Mine parameters can you find at page 2. VAS 18.93 QTS 0.35 Fs 43hz.From Madisound I'm getting VAS of 29.50 QTS of .37 and FS of ~40. Does that sound pretty typical of these 10 MOAPs?
thanks
Yes. I can hear that is true. Match pairs sounds very good.Thanks, so they vary by pair. Either way the calculator for BIB at http://www.mh-audio.nl/Calculators/BIBalt.html brings an acceptable size speaker box.
At least they match the pairs.
These are expensive but are said to sound better that the A10p, the other one I was considering.
Awesome, These are expensive but are said to sound better that the A10p, the other one I was considering.
I have heard the Alpair Maop10.2, Alpair 11MS and Alpair 12p. Keramik, Metalcone and Paper.They should certainly different, but "better" is really subjective, and relates more to personal taste. The A10p is said to have a "vintage" sound, in part because of it's paper cone.
jeff
