Arduino+PGA2311 Ultimate PreAmp with OLED and IO switching
As for using nano I completely concur with Zdr.
Other than that
1) Arduino Micro ( 32u4)
2) If we used a decoder than 3 I/0 pin to select 7 or 8 inputs and two I/0 can be used for selection of two output options.
3) I2C i/o expander for selecting relays.
Zdr if you could support the software changes then I can work on hardware and share the Gerber's and PCB files with you and we could discuss it.
if you want I can participate in the work. in these two days I have been studying how to solve the problem based to yours
aditya zdr
valuable information​
and assuming I have no knowledge of Arduino, I found some info online on how to expand the I / O using a PCF8575 expander connected to a ULN2803 by adding resistors to overcome the problem of driving the relays because the voltage is insufficient and I also added LEDs for signaling the input and output of the various channels. everything must be checked by those who know more than me, see pcd, I can post the gerber file created with Eagle program
Reactions: aditya
Hello,
they use a 328pb Why couldn't I read out here ?, the 328pb is difficult to obtain, the connections PE1 and PE0 are also not used
the 328pb certainly needs another bootloader (minicore) , which one did they use ?
I want to test the project on a breadboard first, and already own normal nano 328p
I would probably make a different version of this design - I recently went back to using tape decks and realized I don't have a way to do tape monitoring. So, I'm going to ditch a second output and connect the remaining output directly to RCA. This would allow to have 5 inputs and 6th relay to switch between selected source and tape monitor.
Hello,
Why would you need PB for this design? I am using normal Nano with P variant.
but sorry ... the three pin connector J18, of which pin 2 (COM) connected to pin 10 of the ULN2003 is not an expansion for a possible other relay? err?
A pleasure. can you send me the Sketche file of the development of this project?
I would like to do some tests to expand the IN and OUT
It will take a lot of time? I also use Akai GX77 and Revox PR99 tape recorders. With pleasure I will buy a ready-made KIT with a tape recorder monitor and 5 inputs
