dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 kHz DAC module
I've a question, in parallel single ended mode (313ohm, 2.6v), it can directly drive an integrated amplifier with input impedance of 10k or 100kohm (pot impedance )? Or is it desirable to have a lower output impedance to to get a better impedance matching hence better sound.
Tell me yours, thank you.
Just finished building the Power, Buffer, and Display boards and assembling the dam1941 system. Everything is working fine and sounds great. I won't be using the head phone feature. Am I correct in assuming that it is safe to cut-off the display board at a point beyond the mounting hole at 6.695"?
I'm ordering front and rear panel face plates for the assembled DAC. I'd appreciate part numbers for the TOS and USB2 jacks so I can get accurate size & cut-out specs. The RCA and BNC information was provided preciously.
Some time ago Soren posted the the bagplate of the Soekris dac1541 which as the same cut out size. I've attach the Autocad dwg with those info. I haven't made a case yet, they should be correct but in case double check them.
  • slim line 2u (1) dam1941_final.dwg.zip
One question: How can I do a true factory reset ? I realized that my set=filter... Commands are still there after flashing firmware/filter package 1.23. So, this is not a complete erase and rewrite...
Backround of my question: I played around with some cuatom dilters and strange enough i got now a highly attenuated signal, but only in sampling frequence 96khz.
My first Dam1941(older one) does not behave like that, so i want to be sure, that any misbehaving custom filter setting are erased and that I get the same volume behavior no matter which sample frequency i feed the 1941 with.
Reload 1.20 stock 4K filters, available on soekris website.
