diyAudio Power Supply Circuit Board v3 illustrated build guide
Hey team,
I'm in the process of building a pair of F5T v3 monos and built the power supplies using PSU from the diyaudiostore. I've had one of the PSUs assembled and running for about a week and upon inspecting it today, noticed the capacitors were bulging/leaking. I assume there's a mismatch between the capacitors and transformer, but I'm not certain. Any ideas what would cause this to happen?
1. Transformer - AN-6224 (1x)
2. Capacitors - 25V/22,000uF (8x)
Thanks in advance!
You are over-voltaging your caps. Rating on the caps is 25VDC. Using a 24VAC secondary after rectification will be about 34VDC. That looks to be what are measuring with a total potential difference of 68VDC from V+ to V-. (34 Volts per rail).
Those caps need to be replaced with higher voltage rating or go down to a x-former w/ 18V secondaries. Given this is the F5T, I'm guessing you want to keep the 34VDC rails so higher rated caps.
In the meantime, I recommend powering it down and not turning it on until the caps are replaced.
Reactions: dirtyblvd
Thanks for the quick reply. If I replaced it with 35V caps is that enough headroom or would 40V be better? Also, is the capacitance okay (22,000uF) or should I increase that as well?
35V will work just fine.
Longer life and ability to experiment with higher rail voltages, go with higher.
For my F6 mono-blocks, +/-24V rails, I'm installing some 50V 18kuF caps rated for 8k hours. The PSUs will probably outlast me.
For the actual Farad value, NP recommendation is 10-15kuF each. As it is Class A, bigger Farads aren't necessarily better as current draw is steady. I believe the larger Farad bank will help with filtering but haven't sat down w/ an o-scope to compare nor run thru the theoretical calculations.
Go with what you can afford. Bare minimum is 35V, 10kuF and will work perfectly fine. Of course, overkill works just fine too. Just make sure you have a way to control the in-rush current on power-up.
Much appreciated. A quick look at the usual sources have 40V/22KuF capacitor options that are ~$20 each. Crazy expensive when I need 16. I was only looking at 22KuF and above, so I'll play around with the filters some more. I used a soft start in my F6 build and plan on doing the same for these, so in rush should be covered.
Reactions: 6sX7
edwinjones4 is building monoblocks so there is a huge extra cost. Power supply and chassis with heat sinks are a large part (much more than 50%) of the cost of Class A amplifiers.
DIY is probably less expensive than buying factory produced used, and equivalent monoblocks used are probably very hard to find.
Reactions: edwinjones4
The Apex Jr. capacitors are a fantastic deal at $3.99, I have a set and am very happy with them. I figure if Nelson uses 15,000uF in the factory build Firstwatt amps, it's a perfectly reasonable value. It also says 15,000uF on the schematic. :yes:
https://www.apexjr.com/capacitorsR.html
Ah. I’m tempted to buy a bunch just to have for future projects.
I got distracted looking for the voltage and missed the farad value in the BOM.
P.S. the links to the schematic and BOM are working in the store but are broken in your first post.
explicative Just got my 50v/15,000uF caps today and put them in my psu. After consecutive 5A blown fuses after startup, I added the dim bulb tester to see if there was a short - it lit up like a christmas tree. Any idea what I've done wrong? All else has remained the same from my previous post (#1,842).
600va PSU
8x 50v/15,000uF capacitor
5A fuse
No soft start board yet...just the CL60's in series. Here are a few more close up pics of the solder pads. I did notice one of the new capacitor leads was touching the metal baseplate during the initial startup, but I've since trimmed everything.
