Anyone know about the mechanics of this technology with respect to low frequencies? If you put a Neo8 type device in a 2-way, does it need a high-pass filter? It takes around 100uF capacitance to meaningfully shunt the low-end signal. Will low-end output be highly distorted and loud... or highly distorted and inaudible? Will the life of the device or output SPL be reduced without a filter?
Yes, you most definitely need a high pass filter. The clearance btw the magnets and the diaphragm is very small...1mm or less. Planars also have very high distortion lower in their operating range. For legit BG neo8, I would not cross any lower than 600Hz if you want reasonable distortion and enough headroom for high output levels. For the PE models I tested 800-1000 looks better. They may be a copy of the BG, but are certainly not exactly the same, based on my measurements.Anyone know about the mechanics of this technology with respect to low frequencies? If you put a Neo8 type device in a 2-way, does it need a high-pass filter? It takes around 100uF capacitance to meaningfully shunt the low-end signal. Will low-end output be highly distorted and loud... or highly distorted and inaudible? Will the life of the device or output SPL be reduced without a filter?
Greg
Hi wout31, so which the correct measurements, this post #5 or post #3? Seems the THD measurements are different.Here is a plot of the ESL-63
Fundamental and reference line at 0,2%
With a sweep measurement you have inter-modulation distortion.
This is 75 dB @ 1 meter in the living room.
You don't state volume and distance
Both are correct, different set of the same model have different measurements due to small building differences. Quite normal.Hi wout31, so which the correct measurements, this post #5 or post #3? Seems the THD measurements are different.
Plus measuring with sweep or single frequency gives different results due to interference in the sweep. Single frequencies give better numbers.
Hi WrineX, I’ve seen that you’ve made both the ESL and planar magnetic (PM) panels. Do you always find that the ESL have lower distortion?
To me no, but it also had to do how well you make your ESL i guess 🙂 i made better planars then i did ESL's 🙂 i think.Hi WrineX, I’ve seen that you’ve made both the ESL and planar magnetic (PM) panels. Do you always find that the ESL have lower distortion?
also not really comparable. unless you go big. my tweeter are 1/6 the size of many esl variants. while comming close in distortion. give that same planar 6 times more surface area and im sure it is as good if not better then the ESL.
here is a larger midrange distortion measurement @ 96 dB @1 meter, (amplifier could not deliver more back then)
and here when normalized
so in the used bandwith 300-4000hz +- 0.12% THD. but its 6 db louder then the quad test though. so i might even had lower Thd then the quads there.
by the way in that test they used both left and right speaker..... thats unfair 🙂 so my panel is doing more work 🙁
Yes, I agree. It’s all about implementation, if it’s done well.
Is the undriven area of the PM’s membrane causes membrane ‘drum-skin’ vibrational modes? Assuming it’s well tensioned
it creates a resonance yes seen here at 205Hz and you also see breakup at 7-9Khz (it also has a cavity resonance at that same spot, so it looks a bit weird)Yes, I agree. It’s all about implementation, if it’s done well.
Here is my youtube channel where i make all my drivers from scratch if your interested 🙂 (i do buy all the dynamic drivers though)This Magnepan video is interesting. They make the drivers from scratch.
https://www.youtube.com/channel/UCeBox1lGM29f72KL2KrDm7A
Yes, I’ve seen few of your videos. Have you tried thinner mylar or use different materials, such as PEN?Here is my youtube channel where i make all my drivers from scratch if your interested 🙂 (i do buy all the dynamic drivers though)
Does this membrane vibrational modes also occur with ESL membrane? Since it’s driven more uniform across the ESL membrane areait creates a resonance yes seen here at 205Hz and you also see breakup at 7-9Khz (it also has a cavity resonance at that same spot, so it looks a bit weird)
i dont know what PEN is , thinner is useless when you have such heavy coil 🙂 it results usually in more troubles in dirstortion. tried 6 micron and 3.. 21 works best all around for tweeters and fullrange.Yes, I’ve seen few of your videos. Have you tried thinner mylar or use different materials, such as PEN?
AN ESL has a resonance as well, but not the breakup thing. since its driven on the entire surface.Does this membrane vibrational modes also occur with ESL membrane? Since it’s driven more uniform across the ESL membrane area
When a planar magnetic has coil almost everyhwere on the foil these breakups move up and above the audio range (i do this in tweeters, not useable in bass panels and is related to the width and strength of the magnets used, and the distance from trace to trace.)
How do you damp the membrane vibrational modes with PM?it creates a resonance yes seen here at 205Hz and you also see breakup at 7-9Khz (it also has a cavity resonance at that same spot, so it looks a bit weird)
You must sell a lot of those. What countries do the materials come from?Here is my youtube channel where i make all my drivers from scratch if your interested 🙂
? materials come from all over. mainly Netherlands, UK, Italy, Poland and China.You must sell a lot of those. What countries do the materials come from?
- Planars & Exotics
- With planars, how low can you go?
