Q17 - an audiophile approach to perfect sound
@tvicol I hope the below schematic per your layout guide PDF is the correct and we can follow the same as the PCB silk screen seems to have some issues in the boards that I have printed. Per the below schematic Q3/7/12 is 2SC2240 which equals KSC1845 and Q2/10 is 2SA970 which equals KSA992. I hope I got the replacements right and also per your BOM suggestions. The only confusion is if you look at the page #7 the "Bill of materials" section the numbering seems to be wrong as 1845 you mentioned as Q2/7/12 and Q10 as 992.
https://github.com/tvicol/Q17-a-QUAD405-audiophile-approach/blob/main/Project description.pdf
Hello Tibi,
I have learned from the last experiments. What I find remarkable is that at relatively low volume I managed to burn out the end transistors. Nothing else happened, as my 500VA transformer is fused at 3.15A on the mains side (so at about 700W, the fuse shut down the amplifier).
From the remains of the last 3 or 4 Q17s I disassembled, I built a new one today, which is playing superbly again. I further expanded my concept in the process. This time I increased C1 from 470pF by 150pF and added an inductor of 3.3 uH in series with R6, but left my snubber of 15nF and 499Ohm in parallel.
Regarding the starting problems of the experiments here, I had them several times, for me it works well when R29 is slightly smaller than R30. R29 + R30 in 330 ohms destroyed the Z-diodes D5 and D6 for me.
I reduced C13 and C14 to 150uF, R29 = 8,2k and R30=10k.
For testing I use a transformer with 60VA and 2x24V AC, which is then 2x35V DC. One module from the current setup consumed 7W at idle. One has 36mV offset, the other 39mV offset.
I still haven't bought OPA1641, my Q17 always have to play with the OPA1611, this increases the oscillation potential!
The current one plays very very well, a bit more neutral than my previous models.
Less analytical like one and less tube sound like the other, something in between.
Regards Tim
Look at this uptodate diagram.
It must match your PCB (except Q12/R42/R43) with the same numbering but with references of available component.
https://github.com/stefaweb/Q17-a-QUAD405-audiophile-approach/blob/main/Q17-Mini-schematic.pdf
Stef.
From the pics , it seems the input jack pin closer to the 1uf capacitor is the
signal - you will see a track on the PCB connecting it to R16.
The other pin (towards the edge of the PCB) is ground.
Yes got it the pad goes to the R16 (22k) which I will take as signal input and the other pad as signal ground. But not sure why does the ground signal pad has that arrow 🙂
One quick update, removed the 10k resistors and replaced with 100R on R29/30. Now with the bulb tester across the 0.1R in series with the positive rail I get only 0.1mV but the bulb is still glowing. Offset is around 0.1mV and the FQA36P15 power mosfet is getting warm but the opp mosfet is not getting warm during this test after 10-15mins. Voltages across the 47/1w resistor is around 2.32v. Rechecked all the transistors and they all seem to be fine and no shorting anywhere. Any other pointers in terms of why the bulb tester is not switching off or should ideally glow less brighter with now less than 0.1mV flowing right now.
Hello Tibi,
a picture of the current setup.
Looks bad, I took an existing board and the small lump of hot glue is L2 (I had to wind something with 33 turns myself). The red blocks on the board in the output are Wima MKP10-630 680nF, only with them the tweeter is super clean. Before that I had only installed Wima FKS3 with 220nF, which was not ultra good.
Test song is e.g. Annett Louisan - Wir sind verwandt 13s to 19s.
This is the second part of the intro in which knives are sharpened in the background.
Regards Tim
That arrow is from footprint connector. I'll rotate this, so will not create further confusion.
As it is now, will indicate ground input signal.
Tibi
