Autoranger for soundcards
Hi Jan,
one question: what series and size are the resistors and caps used in the PCB? I see that resistors are MELF but maybe also other SMD like 1206 may fit? I'd like to stick to proven design, so if you used MELF, I'd use what you did - also for caps. I wanted to order from Mouser the parts so that I am ready to build when the PCB comes in.
Almost there
And a question. How the header pin rows correspond between boards? I received wrong pitch terminated flat cable so I have to connect the headers with Dupont jumpers.
See attached, will that help?
Also, for those of you who don't like to construct the flatcable assembly, these are available from both Digikey and Mouser, part number ISDCB84, manufacturer NKK. Around $ 9.
Thanks. So it follows the IDC ribbon cables keying for odd numbers-connector key side, even numbers-connector flat side. 1 to 3 & 2 to 4 in my example naming. What I was afraid of. Takes to cross the Dupont jumper rows.
Hey, it works. Dupont jumpers connected as discussed. Sacrificial TL082CN for U2,U5. TL052ACP for U3.
What do you know, even low spec opas for crude initial tests can give decent results in Jan's Autoranger.
Here's an FFT with MOTU M4 as signal provider and analyzer. Congrats Jan, a nifty device.
Now to put the OPA1656's on adapter boards and order shorter rainbow jumpers I guess.
