TPA3255 - all about DIY, Discussion, Design etc
I'm not sure why "C" is not showing any voltage. I believe the voltages measured at "B" & "C" are generated by a regulator circuitry internal to the chip while "A" & "D or E" have to be supplied external to the chip. I'll have to read the 3255 datasheet in more depth. Let's try something simple. If you haven't tried a RESET of the amp let's try that. All you should need is a SPST momentary push button between the reset pin and ground pins on the board (if you've got steady hands you could just use a piece of wire as a jumper). The board must be powered up when doing the reset.
Thank you turion64 for your help so far.
I had already tried resetting the amp by grounding the RESET pins. I did it once again by holding the RESET ping while powering up the board before retaking the measures. The measures show the same as read previously and there is still no sound.
Also, C - GND is actually not 0 but more like ~5mV.
The TI datasheet says the reset + ground only has to be held for 1/4 sec past power on and then disconnect the reset + gnd connection.. This is what you did, correct? If yes, try again anyway. If still don't get approx 7vdc out of "C" it sounds like the chips internal regulator for its analog circuitry (AVDD) is bad.
Yes, did exactly as you described for the RESET pin. Remeasured again, still ~5mV out of C.
At this point, unless any of the other forum members have any insights, you may to to contemplate replacing the 3255 chip, if you have the ability to do so. I guess you can try contacting 3e Audio's technical/customer service via email but I heard frustrating stories from other folks. Sorry we couldn't get the amp going for you.
Pete
If you just wanted to see (just because ) you could measure "E & F" points (GVDD AB/CD) to make sure they are receiving ~12V as well. I think I marked the ground correctly this time.
I received a new board back from RMA. It now works as it should, the sound is fantastic!
There are a couple of cracking noises coming out of the speakers when the amp powers up, I was wondering if there is something that can be done to avoid them and how you guys deal with it?
You could put a speaker delay circuit after the amp output if you want. There are Many to choose from in the DIY world that range from simple relay circuits to ones with both delay circuitry + DC protection circuitry.
The one's that quickly come to mind are:
https://diyaudiostore.com/collectio...speaker-turn-on-delay-and-dc-protector-boards
https://www.jlelectronicsph.com/product/blank-pcb-for-stereo-speaker-protect
Another is designed by Pete Millet and is available through eBay.
Cheers, Pete
Danny (on this forum) has experience of this board !! The first time it was plugged in the 12volt regulator burnt out. Manufacturer only used 40volt regulator components on a 48 volt board. Also inductor values in the Power Supply appear to be wrong and hence overloading the regulator !
So if you buy this board expect to do some reworking before you attach to Power !!
Danny has it working now after replacing some components so can probably tell us what it sounds like.
On the Aiyima A09 TPA3255 unit, I have this same unit without the Anti-Pop circuit and yes it makes a big noise when turning on and off with the front switch ! If you turn the power off and on to the power supply there is almost no noise. The latest release of the PCB In this model now appears to include the Anti-Pop circuit and is identical to the Tilear Aiyima A04 TPA3251 model.
How do you like the A09? I’m looking for a 4 channel amp to power my open baffle 3way project. Mid and tweeter with a analog XO and bass driver integrated with active XO.
Mini dsp 2x4 sent to A09 and then different drivers plus sub.
are there reviews include measurement diagrams in "Stereophile" about power amplifier models where the TPA3255 from TI is in use ?
Apart from audiosciencereview, i have not seen any TPA3255 reviews.
I have seen Hifi News test Infineon based class D amplifiers, and they get decent subjective reviews :
https://www.hifinews.com/content/agd-gran-vivace-monoblock-amplifier-lab-reporthttps://www.hifinews.com/content/ta-pa-1100-e-integrated-ampdac-lab-reportIt would be nice to see one of the cheap TPA3255 amplifiers reviewed. If the Infineon IRS2092 or other driver/modulation IC is acceptable as a solution, then the TPA3255 should be too.
Shadders.
