Hornresp
hornresp got flagged by windows today as a virus
completely crazy but it happened i cant imagine anything further from a virus.
i had to reinstall it and force it to allow it
Hornresp is being flagged as infected with a virus because the website that's hosting it doesn't have a certificate installed.
David -
I dug into your whois records, and it looks like the site is hosted by "hosteurope"
Here's how to secure your website:
https://danielpietzsch.com/articles/he-ssl
If I can do anything to help, LMK
Bummer about Mr. Mcbean hope he is alright.
Does anyone use hornresp to simulate low pass filters? I've trying to duplicate the schematic on the left but things don't look right. Maybe I am entering in things wrong in Hornresp?
I could swear that I've used Hornresp to make closed back transmission lines, but for the life of me I can't get it to work.
According to the instructions, "Double-click the Cir or Fta label in edit mode to select the Clo closed horn mouth option. Not applicable to direct radiator loudspeakers, tapped horns, multiple entry horns or single segment horns other than Con, Exp or Par."
But when I do this, nothing happens.
I suppose the "serial" values will all be calculated as series in a row. so you have a resulting impedance of L1+C1+R1 (as shown on hornresp-screen) attenuating the speaker. therefore the bass response is so low.
try only including value for L1 to and gradually increase R1 value to check the result.
I don't think you can simulate your entire crossover network in hornresp.
all the best to david mcbean!
Works fine for me, though with driver 'Nd' it returns an 'Error- closed chamber', so can't calculate.
lol I literally spent about three hours trying to get this to work yesterday
I looked at it again today, and now I see the issue:
I was trying to click on "fta" under the sub menu titled "horn segment flare"
That doesn't work
Where you have to click on "fta" is in the main menu, on the top right. I never noticed it was there.
Hello everyone! Does anyone know how I put 2 graphs on hornresp to compare them (just like the picture)? thanks!
You cannot display two graphs like this as far as I can think through. You can export the data from the two graphs and use REW to view them at the same time. You have to export them as an FRD file and REW will be able to import them in that format.
Only on my phone at the moment so can't check exact locations but there is definitely an option to Capture Current trace then once you've called up you other record Display Captured to show them both together. Can't remember if it's in a right click contextual menu or one of the main ones though. A quick search of the helpfile for the terms I've capitalised will sort you out in no time though 😉
Thanks! :up: I really, really need to read the HELP File after every update! Search 'capture' for a bunch of options!
Oh are you guys teaching me something new? That Master McBean is a busy man.
So below is the fruits of my searches. Two different enclosures. A very looooong front loaded horn and a sealed subwoofer for a client of mine. Ctrl C on file one. Next up open the second file and calculate. to compare hit tools, Compare captured and you can see the two files. I didn't know that you could do this randomly. I do it consecutively regularly. File after file in order. Reading that manual always teaches me something new. Sorry for the misleading comment above.
I am getting a runtime error 76 path not found when trying to import or export anything. am i doing something wrong?
Permissions. Whatever you're running, your username would seem to not have access rights to the Import or Export subdirectories under Hornresp. And the import and export file targets are placed in one of those directories before you try, correct? Make sure filenames themselves do not contain a weird character that the system interprets as a control character.
