First Watt F7 review
I will try to write something more about the sound of the F7, more than the fact that it is 'sensational' - after all, we make various constructions to make it sound well, right?
My first impression, a few hours of listening to the F7 after first turning it on, was that it felt as if the sound was piercing my ears. Then, I noticed that I listened to sounds with great ease, effortlessly, simple, easy and most importantly, pleasant - I realized how much effort I had to put into listening in advance for the brain to produce intelligible and acceptable sonic content of an individual in class individual homo sapiens in the hearing utility category.
If this first listening session was 'in the dark', I would say that the amplifier is tube-type, possibly with some addition of silicon in the pre-voltage. All sounds were reproduced correctly, each instrument played well and freely, with its own expression and dynamics, the amplifier did not allow anything in the soundstage to exist at the expense of something else, which is the main feature of tube amplifiers. But, it was a solid state amplifier, all solid state!
The FIRST WATT F7 by PASS LABS is opening the door to the future of audio in the third millennium.
(Google translate Polish-English)
F7 sound is a lot relate to speaker you connect ,there is a good testing here with some spk, link: F7
The problem of the necessary amplitude of 2.7 Vac to fully drive F7 was solved by inserting an additional gain stage on operational amplifiers (I used MUSES01, MUSES8820).
I enclose a diagram of this additional circuit k = 3.
Measuring the power of the amplifier on the full signal gave the values 23W at 8.6R and 45W at 4.4R, in both cases the amplitude of the signal at the output was 14.2Vac.
The F7 is great, listening to music gives me a lot of fun! Honestly, I do not want to make other amplifiers, because they are not able to give the quality of the F7.
Greetings,
Jan
Having built several F7 clone amplifiers using the ALF08x16 lateral FETs I finally got around to modifying one of those amps to use the ALF16x16 FETs. Only one resistor was changed, but of course the pots needed adjustment. The resistor change was calculated based on the FET transconductances using the equations supplied in post #442 https://www.diyaudio.com/community/threads/first-watt-f7-review.275921/post-4585617.
I found that the increased transconductance of the ALF16x16 FETs make a noticeable improvement to the sound. With the larger TO-264 footprint they could be run at higher voltage and idle current.
I intend to see if I can match pairs of ALF08x16 FETs without current hogging problems to get the same results.
Did you changed the value of Rfbp or Rsen ?
