New Markaudio Drivers
Thanks for the replies Dave. It really does feel like going back home to diyaudio, lol. I've only gone through a couple of 7MS listening impression threads, but I haven't really seen one yet that compares it to the 7.3.
Would the extra effort of modifying the driver brace for the MS be justified by any improved sonic characteristics? Or if not improved, a fun change in character that's worth exploring?
After ordering the newish CHR 90 week and a half ago, it finally arrived, and mine arrived two drivers within a single box, so are they matched? I've just hooked the raw drivers to a spare Rega Brio R integrated amp I have lying around unused and hooked to a FM tuner (I mainly listen to analog music source) so probably the last person on earth who don't listen to nor own streaming music devices!
Without the drivers sitting in any box, I can't tell about the bass, but I'm rather impressed with the high frequencies coming out of this new model of this size! What would be a good box design for these CHR 90s?
I just noticed the CHN40 too... Looks like it is going to be even more affordable the the CHN50, should be interesting for PC usage, sound bars, etc. Also if one is planning to build one of those floor to ceiling line source arrays, this would keep such projects cost effective?
I just changed to CHN50P which is paper cone version of CHN50.
Comparing with the OM-MF519 I listened before, the 50P seems a bit more natural and organic especially on vocal playback, mid-bass also more texturized.
Contact them by mail to see when they will be back in stock. But if i'm right they are waiting for a big delivery of mark audio drivers right now and they can arrive anytime now. I also need some and contacted them and they did respond very fast and friendly.
yes, probably more so than the A7.3 due to monoSuspension.
Given the difference in depth, a fairly thick spacer is all that is needed. Getting it exactly the right size might be a bit tricky.
dave
Another option which may be worth trying would be to fill the gap between the driver/holly brace with a product like Acroglas Gel which is a 2 part epoxy kit for bedding gun stocks. You would first coat the back of the driver with the supplied release agent before mixing the epoxy. If done correctly, the driver would have a perfect fit with the holly brace with no side forces probably resulting in improved sound quality. The driver and the holly brace would become one. The only downside of this process would be that it could be a challenge removing the driver once the epoxy cures. If this is an issue, I would try backing all the driver screws one or two rotations and play the speakers to vibrate the the epoxy loose. Another option would be to shove the speakers into the freezer. This will usually break the epoxy bond.
Yes, it should go in reasonably, albeit how closely depending on your specific units -while they were designed to have approximately similar loading parameters, they are not exactly the same, and other than the basket and magnet, as far as I know, they don't share any components. The pensil type alignment, being a traditional type of acoustically large / efficient design, damped to semi-TL levels / to suit the system gives a bit of flexibility in this regard. So I stress that this should not be taken as an euphemism for 'it will go into any box designed for xyz'. 😉
