Thanks guys for your Andrea clock impressions and blogs. I considered last minute to sell to a potential buyer before unsealing the SinePi but your impressions made me push on.
So after soldering up the crystal, powering on with 13.2V and getting a i2s lock on the Q3 I'm stuck...
Andrea was kind enough to help me over the weekend troubleshoot and we are thinking the TransportPi may be the issue?
Has anyone successfully implemented this chain? FiFoPi Q3 -> SinePi -> ReClockPi -> TransportPi (OPT OUT) with the 5.6 MHz clock?
We are suspecting the TransportPi doesn't handle 5.6 MHz clock? If that's not the case, we can focus on something else in the chain.
Cheers
Cheers
Cheers
Hi
that doesn't work for me, but I don't have a ReclockPi, only TransportPi. I use clock 5,6 with a frequency doubler. That's working.
Package received Ian thankyou.
If I were to feed the new 3v3 and 6v6 battery psus with AC, and assuming your on board rectifies and filters are better than 5v USB smps. What is an reasonable trafo VA rating assuming powering low draw loads such as clocks and fifo clean.
Jim
Thanks for looking into this guys (including Andrea from afar). My main objective in my DIY arc is for an optical S/PDIF toslink output to my Chord DACs. I avoid USB. A SOTA clock should be something wonderful if it works, but these issues happen.
I'm willing to upgrade to a Lundahl transformer if needed, but I doubt that will help. I'll hold off researching doublers till Ian checks the minimum.
Andrea's following this issue in realtime and just verified my clock is soldered properly.
I usually try to use minimal amount of solder, but in this case I went overboard to make sure the connection was not the issue.
After the crystal is solid, I just plug in LiFePO4 13.2V to power up. I get an i2s lock. When I unscrew the SMA, the Q3 flickers indicating no clocks. I screw back in the SMA and get an i2s lock. I'm just not feeding my DAC afterwards.
I can also wait for a TransportPi II if that's what it takes as I can work on the power projects in the meantime. The TransportPi probably didn't have 5.6MHz in mind when released. Which is perfectly understandable.
@A123
here my modifications of the TransportPi
What's replacing the Pulse transformer?
So the doubler feeds the TransportPi a more friendly 11 MHz?
5.6 MHz never worked, but 11 MHz was a breeze?
Cheers
I have tried the drixo 5.6mhz with the transportpi (spdif out) and my dac could not maintain lock and was distorting on high frequencies. But Via hdmi I2s theres no problem... It seems like the 5.6mhz is too low for spdif output on transportpi. I don't use spdif so this was not an issue for me.
Thanks for weighing in @tubo
That gives me more confidence the implement on Andrea's side was not the issue. I was worried I made a misstep even though it was a straightforward soldering job. Or even if the cable was the issue, but getting an i2s lock sort of defeats it's an cable issue or an implement issue.
@A123
Just recall my TransportPi design.
To achieve a better low jitter performance, TransportPi makes one more time re-clock. So, it will need a MCLK minimal at 256Fs. That means, for a 44.1KHz music, the lowest MCLK frequency will be 11.2896MHz.
22.5792MHz and 45.1584MHz are also good to go no problem.
Ian
Ian
@iancanada
Many thanks for looking into this issue. Adding a doubler to get to 11.2896MHz is not the end of the world. I'll do that early 2022 and give feedback at that time.
In theory that should work and @Cerole, sample size of one, confirmed this solution works for his use case.
Going through this process actually helped with my final project design and terminated the process of pursuing DIL14 clocks. I think this is a good endgame solution when all is said and done.
I was seriously considering the Russian clocks @5.6MHz and that would of just been one big headache. It's a special order and once receiving the clock, I would have no answer how to solve the 5.6MHz issue. So it should all work out in the end both headache-wise and added expense-wise.
@Cerole
Damn, if you didn't provide the doubler solution, I would be in a very rough spot. So thanks again for sharing your experience.
The dream will have to wait a little big longer before experiencing the SOTA experience.
@Cerole
bumping this as it may have gotten lost in the shuffle.
Jim
1. Iancanada 1*SiniPi fully assembled, 1* UcPure, 1* LifePO4 Mini 3.3V, 1*Oven KIT, 2*6” and 2*10” SMA cable
2. Cerole 1*SiniPi fully assembled, 1* UcPure and 1*Oven KIT
3. A123 1*SinePi fully assembled with RF relay (SiniPi fully assembled), 1*UcPure, 1*LifePo4 Mini 6.6V
4. hires 1 * UcPure
5. pz1 1* siniPi fully assembled, 1* LifePO4 mini 3,3V
6. schiirn 1*SinePi KIT
7. linh0983 1* RelockPi, 1* LifePO4 Mini 3.3V
8. terry22 1*SinePi fully assembled, 1*Ucpure 15v, 1*Oven KIT
9. Narukas 1*SinePi fully assembled, 5* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
10. Raj1 2*UcPure
11 Eduard 1* SinePi fully assembled
12 SimonJ 1* SinePi fully assembled (can be kit if needed), 2* UcPure, 1* Oven KIT, 1* LifePO4 Mini 3.3V
13 Oyvind 1* LifePO4 mini 3,3V
14. kunlun121 1*SinePi fully assembled, 4*UcPure, 2*Oven KIT
15. Tubo- 2 SinePi fully assembled, 2*UcPure, 2* Oven kit, 2*6” and 2*10” SMA cable
16. wlowes 1*SinePi NOT assembled
17. AirAir 1*UcPure
18. trial and error 2*LifePO4 Mini3.3V, 2*battery holder assembled
19. jrocker 1*SinePi fully assembled, 2* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
20. ernesternest 1* UcPure, 1* LifePO4 Mini 3.3V, 1*Oven KIT
21. puuchan 1*SiniPi fully assembled
22. M_Balou 1* SinePi fully assembled, 1* Oven KIT
23. Atom6422 2* SinePi fully assembled, 2* Oven KIT, 2* LifePO4 Mini 3.3V, 2* ReClockPi, 1*StationPi
24. Photochum1 1 x SinePi fully Assembled, 2 x ReClockPi, 1 x StationPi Pro, 1 x UcPure, 1 x Oven Kit, 1 x HDMI Transmitter MK II
25. jimk04 1x sinepi assembled 1 x oven kit. 2 x LifePO4 Mini 6.6V, 2 x LifePO4 Mini 3.3v , 1 x StationPi/ pro if available
26. Paul M 1x SinePi fully assembled with RF relay, 2x Oven kit
27. efrank 1x SinePi Fully Assembled w/Relay, 1* LifePO4 Mini 3.3V
28. Ilgavro 2x sinepi not full assembled
29. mksung 1*SinePi SMT finished KIT, 1* UcPure
30. Morde 3* LifePO4 Mini 3.3V
31. casshan 1*SiniPi fully assembled with RF relay, 1* LifePO4 Mini 3.3V
32. Supersurfer: 1x UcPure, 2x LifePO4 Mini 3.3V
33. igor61> 2x LifePo4 Mini 3.3V, 1x UcPure
34. Subbu K: 2*LifePo4 Mini 3.3V, 1*LifePo4 Mini 6.6V
35. Greg Stewart 2x SinePi fully assembled with RF relay, 2x Oven KIT for SC-cut crystal, 2x 6" SMA coaxial cables
36. blue9527 1*UcPure, 1*FiFoPi Q3, 1*ReClockPi, 1*HDMIpi MkII, 1*CCHD957 XO adapter, 4*6" uFl cable, 2*4" uFl cable
37. Mobilux 1*SinePi fully assembled with RF relay, 1*UcPure 3.3v
38. jiacheng 1* SinePi SMT finished KIT, 6* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
39. byun3652 4* UcPure, 2*LifePO4 Mini 3.3V
40. AudioDAC 1*ReclockPi, 1*SinePii fully assembled with RF relay, 1* UcPure, 1*Oven KIT,2*10” SMA cable
41. Rrbs 1x SinePi fully assembled with RF relay, 2x 6" SMA coaxial cables
42. Sebbyp 3x SinePI fully assembled with RF relay (can take the finished kit too), 10* UC Pure 4x Oven Kit for SC-Cut Crystal 2x 6" SMA Cable
43. Stephen1212b 2*SinPI fully assembled with ref relay, 2* Lifepo4 mini, 2* oven kit, 4 * 6” sma cable
44. triode4 2 x SinePi fully Assembled, 2 x ReClockPi, 1 x StationPi Pro, 1 x UcPure, 1 x Oven Kit, 2 x HDMI Transmitter MK II,1 x FIFOPI Q2, 2*6” and 2*10” SMA cable
45. S610adam 2x UcPure
46. Aguaazul: 2 * 1* SinePi fully assembled (can be kit if needed), 3 * UcPure, 2 *10" SMA coaxial cables, 4 * 6" SMA coaxial cables. 1 * StationPi Pro,
47. sumire 1*SiniPi fully assembled, 2*Oven KIT, 4*6” and 2*10” SMA cable, 1*ReClockPi,1*StationPi Pro,
48. geoturbo 1* reclockpi, 1* sinepi kit, 2* 6" sma cable, 2* ucpure, 1* stationpi pro
49. bferg 1*reclockpi 1*sinepi fully assembled (kit ok if needed) 1*fifopi 1* transport pi 1* Stationpi pro
50. duster1 1*SinePi SMT finished KIT
51. JanVeg 1x SinePi fully assembled with RF relay and 2*6” and 2*10” SMA cable and 1 UcPure
52. rowli 3 x UcPure
53. ibraino 1*SiniPi fully assembled, 1* UcPure, 1* RelockPi, 1* LifePO4 Mini 3.3V
54. Michl2604, 1*ReclockPi, 1*LifePO4 Mini 3.3V, 1*LinearPi Solo, 4*6" uFl cable
55. seatrope, 2* Oven Kit.
56. Rullex 1*SinePii fully assembled with RF relay, 2* UcPure, 2*6” and 2*10” SMA cable, 1*ReciverPi
57. drone 1*SinePi fully assembled, 2*LifePO4 Mini 3.3V, 3* UcPure, 2*6” SMA cable, 1*LinearPI-Dual, 4*2" uFl cable
58. Myint 67 life po4 mini 3.3v
59. JimS 1*SiniPi fully assembled, 1* UcPure, 1* RelockPi, 2* LifePO4 Mini 6.6V
60. acg 3 x UcPure
61. matjazsket 1*SiniPi fully assembled, 1*SinePi SMT finished KIT, 1* UcPure, 2* LifePO4 Mini 3.3V, 4*Oven KIT
62. sebmck 1* SinePi fully assembled, 1* SinePi fully assembled with RF Relay, 2* LifePO4 Mini 3.3V, 2* 6" SMA cable, 2* 10” SMA cable, 1* StationPi/ pro if available, 2* Buffalo I/V board Adapter KIT, 1* LifePo4 Mini 6.6V
63. namlee 1 * SinePi fully Assembled, 1 * ReClockPi, 1 * HDMI Transmitter MK II,1 * FIFOPI Q3
64. deanoUK 2*SiniPi fully assembled
65. Thermio 2*SinPi finished kit, 2*Oven KIT, 2*6” and 2*10” SMA cable, 1*LifePO4 Mini 3.3V
66. calebwong 1*FifoPi Q3, 1*ReClockPi, 1*HDMIpi MkII HDMI transmitter, 1*HDMIpi HDMI to I2S/DSD/DoP receiver, 1*No.24A, 1*BridgePi USB streamer adapter, 1*SinePi fully assembled with RF relay, 1*No.27
67. rpiaudio 1*LifeO4 pure power supply MkIII, 1*ESS controller, 1*9038Q2Mpi Dual Mono Plus DAC HAT, 1*I/V STD MkII standard OPA I/V board, 1*ESS controller extension kit, 2*2.5mm metal standoffs for RPI lot of 4 sets, 1*GPIO I2S/DSD terminator KIT (SMD finished), 1*Free I/V STD board finished untested for parts (limit 1 per order, OPA not included), 1*StationPi PCB KIT, 10*26650 battery holder with assembling service.
68. bogdandascalu87 1*SinePi SMT finished KIT, 2* SMT XO socket replacement for FifoPi, 1* CCHD957 XO adapter kit lot of 2, 1* NDK 2520 XO adapter KIT 4 in package
69. josephus-69 - SinePi SMT finished KIT
70 lindamar 1*SinPi fully assembled with RF relay, 2*Oven KIT, 2*6” and 2*10” SMA cable, 1*LifePO4 Mini 3.3V, 1*LifePO4 Mini 6.6V
71 Crom 1*SinPi fully assembled with RF relay, 1 x oven kit, 3 x UCPure, 2 x SMT XO socket replacement for FifoPi
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
60. acg 3 x UcPure
Hi Ian,
package arrived with a little delay due to formalities with customs
ReclockPi works great together with my DDDAC. Nice improvement!
Thank you!
Next step is to install LifePO4 Mini 3.3V (together with existing UCC) for FifoPi clean side. For the input side of LifePO4 a USB charger really is sufficient? Would be great, but I'm a little bit unsure with this point. Would a linear power-supply or a high quality smps bring a benifit, or is the LifePO4 input that much decoupled from the clean side?
Thank you!
Can't complain on the mail, letter arrived today with some nice stuff. Tnx!!!
Hi Ian,
The MINILifoPO 3,3v states that the psu for loading the batteries cannot be shared.
But what will hapen if I share a 5V psu for both RPI and the MiniLifePO 3.3.V?
Can you explain your question more?
Ian
Hi Ian,
Thank you!
Thanks guys for the updates. I'm glad that your packages arrived safely.
@michl2604
You can try better supply for the input side and let me know if you get improvement.
Also, please do let me know if you can not track your package. Or didn't receive it after two weeks.
Ian
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
