@Zek
If i remeber for example in JLE construction is comment "do not use power supply with two output"
So i started to interest why? Could You explain something why one of PSU is good for TPA amplifiers and another not.
Sylph-D200 TPA3255 Stereo (Ready to Run) Amplifier Module | jlelectronicsph
Recommended Power Supply
(NOT INCLUDED)
- 36V DC to 48V DC
- Single supply SMPS 350W or higher.
- DO NOT use dual output types!
Where is the problem?
(NOT INCLUDED)
- 36V DC to 48V DC
I guess dual output is 36 - 0 - 36 volt types. If the amp board is for single output then it’s quite obvious
Bendix,
I believe your “two output” is referring to a bipolar power supply.
One that ouputs +/-36v. That type cannot be used with TPA3255 amplifiers.
Thanks Kjeldsen & Vunce.
I didn't think of it 🙂
I thought it was about something more serious 🙂
For example something like this:
Zasilacz impulsowy 36V 360W 10A CNC LED Reprap - Sklep internetowy AGD i RTV - Allegro.pl
I read in the descriptions here that a power supply with two outputs is not suitable. How to understand?
This SMPS is correct, it has a single output
is there an alternative for 3e audio TPA3255 1x480W 1Ch
was planing to build two mono units with balanced inputs
can seem to find a suitable replacement since 3e audio no longer has anything stock
any advice?
any advice?
any advice?
Sylph-D400M TPA3255 PBTL Mono Single Supply 48V RTR Amplifier Module | jlelectronicsph
any advice?
You can go for this one, it also supports balanced mode but you need to move a resistor. The OP amps are also updatable in DIP8 socket
Assembler amplificateur de puissance Hifi TPA3255 BTL Mono classe D, 300W C7 36 | AliExpress
If you need a finished Mono Block with a TPA3255 also this one :
Amplificateur de puissance audio mono haut parleur 2020 W, gamme complete/caisson de basses TPA3255, 600 | AliExpress
PCB shows TPA3251BTW : there is a new TPA3255 with fully differential OP amps 1632 :
You re right, two versions : TPA3251 + TPA3255 available.
Same PBC, same components, just a different TPA chip ) my bad
D
Deleted member 148505
@Zek
(NOT INCLUDED)
- 36V DC to 48V DC
We have changed the description to "Do NOT use split rail power supply".
We have a cheaper option TICore400M TICore400M TPA3255 PBTL Mono Single Supply RTR Amplifier Module | jlelectronicsph
With jumpers for Slave, PFFB and BAL/SE. OSC IOM/IOP headers for multi device sharing a single power source.
Dual mono setup almost sound the same as the stereo modules. Though I think the sound stage of the mono is "taller" like there's a speaker on top ceiling. But maybe that's just me...
It's a pity, brother, that you live on the other side of the world
English please
dave
diyAudio moderation tem
In English:
TPA3255 Digital Power Amplifier Board 315Wx2 HiFi Dual Channel High Power Class D Audio Power Amplifier Board|Amplifier| - AliExpress
What case can I use with it? Is there a complete kit, assembled or not?
Aiyima A08 (comes with 36V 9.5A power supply installed)
I'm interested in upgrading the caps in the Aiyima A08 if any (even subtle) improvements? Best to just match the values 4x 1000uf 50V caps or could I increase them? If able to increase, max values? and would I need to change anything else? Should I look at changing any of the other caps? Which caps are recommended? Nichicon KW series...? Thanks so much.
- Class D
- TPA3255 - all about DIY, Discussion, Design etc
