The BA-3 as preamp build guide
ra7
Joined 2009
Ventilation is a good call. The base does have feet to allow air to flow under it, but adding vent to the top will only help.
The caps are Panasonic EZP-E 10uF that I purchase for another build, but never used. So far they sound good, but at the moment my hearing is jacked up. I had a procedure on my left ear and can't heat s#!t out of it.
I am working on something similar. Just applied the first coat of tung oil. The hot air gets trapped without vent holes.
Joined 2017
C3 fancy Mundorf caps...
Hi friends
I have one of those :rolleyes:-questions...
I'll use some Mundorf EVO at C3, they're the white ones with red print on them.
They come with one leg short, the other long. Probably the long leg indicates the outer foil?
I know they're not polarized and could be placed either way. But is there a "more correct" way, like, long leg closer to the bypass-C3?
Thank you, enjoy Sunday!
d.)
I got some of those Mundorfs measured and it seems to be consistently the short leg, that is connected to the outer foil. They also say so on der web page:
MCap SUPREME EVO Oil | Mundorf EB GmbH
Asked myself the same question and connected the outer foil towards the 332R shunt resistor (facing towards the trim pots). Wisdom has it that one should connect the outer foil to the lowest impedance to ground so noise can easier be shunted. Recently I slapped some FT-3 teflon bypass caps on mine and didn´t care much as those are in a metal housing.
Of course I could be wrong but that´s at least how I did it.
Have great day :wave2:
Joined 2011
Amusing video:
YouTube: Are Your Capacitors Installed Backwards? Build this and find out
... although I think the gizmo would be 5% more useful if the left and right LEDs were different colors. Just another clue to help the human operator remember which end was low-amplitude. Memory needs to remain correct and active, during the 5 second pause when he looks for the marking pen, picks it up, and moves to make a dot or line or 5 pointed star, on the just discovered "Outside" terminal end.
_
Joined 2017
And a follow-up, hopefully little more elaborate this time: C3 is 10 pF to allow good performance into output-stages like ACA etc with relatively low input impedance? And could very well be reduced to well below 2 uF (if it would feed a F4 or a Sony VFET only...)
(This is the result of greedily running after cool project without understanding the details and then waiting too long to finish it.
sSsiigh, I mean, sorry!)
I beg to differ. I use FT-3 (0.22uF) to bypass, connected each to C3 close to the V-, and Bob is your uncle! Nice crisp sound for me.
I am convinced however that adjusting H2 and H3 has a profound influence to the tone and dynamics of the BA-3 FE than changing comparable type of the capacitors on the output.
I have a pair of FT-3 caps in 0.22uF and 0.1uF values, so may through them in and see what the effect on sound is.
FT-3 are awesome
For sure those FT-3 are awesome bypass capacitors - I use them everywhere, where I can fit them. My comment was regarding the "polarity" meaning the orientation of inner and outer foil of the FT-3 cap not being that important, as they are shielded in a metal housing. I wanted to hint at those caps and the shielding topic. :cheers:
