Fixed gain field recorder?
Mojo i2s data ...
I hear some crackling in a recording when hitting the mic - so some sort of very dsitorted throughput 🙂
I've assumed offset binary rather than two's complement code for the MOD outputs, based on something I found on Internet. If that's wrong, you get very gross distortion, but that will also be very loud.
Does the MOD6 tend to be equal or opposite to MOD5 when the signals are small?
OK - all my trials including the "crackling" was at 44. The last I did before giving it (me) a rest was to strap it for 88. I did never succeed with double speed - not this time either.
Next efforts will be for 88 and I'll check the Mod output. I should try to make it work at 88 from the EVM coax before more tests on the Dem output. But now there *will* be 2 days rest as I'm now an hour drive from the gear 🙂
Marcel, again, immensely thankful for your tireless and prompt support - kudos!!!
OK. I was not sure about how it works... but maybe this is not in play if you tap the Modulator output. Maybe the only thing I need to care about is to activate the Modulator output and the all other straps are out of play... The Manual is not so clear about that but maybe it is obvious... 🙂
At it again... found a cabling issue but now fixed. Still no success... Here comes scope shots of the situation. Hover on attachments for descriptive file names...
Seem to be no i2s data coming out... checked connector numbering... seem OK...
Besides, the bit clock is quite irregular. I'll see if I can do some checks on my FPGA board, after all that's why you sent it to me. It won't be today, but hopefully still this week.
