Aleph J illustrated build guide
Hi guys (any gals?), I'm seeing ~5-7C difference on a couple IRFP140 packages. Two are hitting 59-60C while the rest are at 53-55C. I'm about to take apart and re-apply thermal paste, as I suspect I was too skimpy on it. Both are on the one side, so it seems possible that was the first amp board I assembled. I became more comfortable and liberal with the paste on the 2nd board assembly
Or... do we expect this sort of delta between units?
Is this what you mean?
Right Side
Q6 59C R17 .410
Q5 52C R16 .380
Q8 60C R19 .399
Q7 52C R18 .390
Left Side
Q6 53C R17 .373
Q5 55C R16 .389
Q8 53C R19 .375
Q7 55C R18 .393
During the build I did notice a couple of the .47ohm resistors were out by the high side of their 10% tolerance. But I tossed them in anyhow. At this point I'm wishing I had made note of where they were placed. I'm fairly certain they ended up the R20-R23 parallel network.
ResisterClone
Joined 2011
Here
ResisterClone
Joined 2011
I’ve always taken into account the thermal expansion of metals when torquing dissimilar metals…aluminum generally speaking expands twice that of steel…so yes it makes perfect sense to use very slight pressure when sucking down transistors. The key is getting all the same pressure in any case.
