LuFo Amp - 39w SE Class A from 28v Rail
Here’s a DATS measurement on two 20mH ERSE in series. A few more mH. Not a bad thing. Resistance came in a little higher than expected. I assume no added series resistance is needed?
It depends on what bias current you are looking for - I am running 1.5R + 0.5R from the MOT. So you might need circa 0.5R more in series. Can you show us what the impedance sweep plot looks like?m
If you stuck them end to end you might eek out a few more mH. 🙂
Here is the impedance sweep that I got for my custom made ones. Very linear over audio band with respect to impedance and phase from 20Hz to 20kHz.
970242d1627417939-susylu-custom-lufo-inductor-2-dats-plot-jpg
Interestingly enough, X, the highest mH measurement comes from a t-shaped configuration. Side by side or end to end both resulted in about 37mH. T-shape is almost 45mH.
Ok! Drum roll please!
Just took some more measurements on the 20mH ERSE inductors. The magnetic fields are playing some fun tricks. I re-soldered the series connection and took measurements in all the previous positions. One of the higher readings was in fact the end to end at 54mH. I thought, how could I possibly get a higher reading. Then I put them side by side. 71mH!!! Is there any potential downside to this configuration? The impedance sweep is still linear in either configuration.
Side by side makes sense since both ends allow the magnetic field to reconnect - sort of like a toroidal choke with two huge air gaps.
71mH and a linear impedance sweep sounds like a winner to me. And it’s quite compact. Not sure how well it will do under full DC load but let’s see how it goes.
It would be interesting to compare the sound quality vs the MOT.
