The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB
SLBs looking pretty good in Poseidonvoice’s NPXP (Nelson Pass Experimental Platform) amp:
Nelson Pass eXperimenter's Platform (NPXP)
The single rail SLB is now also prominent in Tungsten Audio’s linear external power supply for his Pass Sony VFET lottery amp:
958503d1623249327-diy-sony-vfet-builders-thread-img_1106-jpg
DIY Sony VFET Builders thread
X,
Is there any issue with using only the positive rail from the dual rail SLB? I have monoblocks each with their own Power Supply, but may want to switch from a dual rail +- 24V supply to the single rail 36V for the Sony VFet amp just by swapping transformers.
Thanks Vunce, I would only replace it if really necessary... I have more than enough aluminium HS in hand, which I ordered - so I would like to use them. 🙄
If the distance is an issue though... I would order something else.
Do you understand what I mean?
Cheers!
Edit: I now remember that I replaced C21 and C22 with some bigger parts, because the needed were out of stock - they don't fit 100% on the pcb... as shown on the photo above. Is the gap between the capacitor and the board ok?
Excuse my beginner questions. 😉
Update on my dual SLB build. Successfully running Zen Mod Babelfish J2 boards. Using Antek 4222, 400va with 22v secondaries. Getting 26.9v under load with the SLB pots fully turned for max dropout. 20v secondaries would get me to 24.4v but in a 5U deluxe chassis I have enough heat sink to make it work. I think the SLBs are doing their job really well. That said, I have a pretty major noise problem resulting in some toroid buzz that seems to be coming through to the speakers. I can hear it from my listening position when nothing is playing and during quiet passages. This is the case with all my amps which leads me to believe I have DC on the line and overall dirty power. Gathering parts for a DC trap and Fo-Felix boards now. Fingers crossed that finally quiets things down. The SLBs though, awesome.
