What’s On the Bench Tonight (OBT)
Hi Tubelab,
How is your UNSET testing coming along? Looks like a really cool amp - looking forward to seeing it fully working.
I have a question for you, is there a good source of a lot of 7370 tubes somewhere?
Thanks,
X
The UNSET testing is proceeding slowly. There are too many things diverting my attention right now. There have been too many days where I don't even get to listen to my working UNSET.
I have never seen a 7370 tube before, so I had to look it up. It looks like a 5687 with a 40/20 volt heater. These odd heater voltages were often found in telephone systems. Good NOS tubes are hard to find for them.
nice table, is the headshell removable?
Yes, it is but is not a traditional cylindrical mount. It has two holes that screws into a flat milled onto the bottom half of the blue aluminum tip that appears to be bonded to the carbon fiber tone arm shaft.
My initial measurements of the FFT of the noise floor shows that the preamp is very quiet at -120dB noise floor at 1kHz for 47kohm and 40dB gain setting with no hash anywhere on the tilted 1/f noise floor. There is a small blip at 60Hz which I think is EMI picked up by the 4 skinny wires from the cartridge through the tone arm.
Thanks for checking! I think I am going to redesign the amp using an ECC99 which is similar but uses standard 6.3v heaters. The 7370 has been getting harder and harder to find.
A new speaker design was on the bench last night July 11, 2021: this is a 6.5in 2-way design that I am developing for LSA. The predicted (blue) and measured response (orange) looks excellent. Another passive “Harsch-like” crossover with asymmetric slopes and positive phase on both drivers. XO frequency is at 3.8kHz.
attachment.php
attachment.php
attachment.php
Predicted impedance:
attachment.php
Listening in mono - driven by TD7293 amp, it is sounding excellent. Very nice tonal balance and clarity. The distortion on this OEM woofer is very low and it has a wide bandwidth allowing such a big crossover frequency.
On the bench tonight, July 14, 2021 is the LuFo Lite - a very simple amp that drive a few watts into either speakers or headphones. I am testing it with a 12v SMPS so only 8v after the cap multiplier. It is running at 2.6A bias current and I am not sure why it is so much higher than the simulation that was predicted (1.7A). However, 8v seems perfect for the heatsinks that I have as they run 43C and the music is plenty loud.
Here is a video of its first sound playing on a 3FE22 test speaker.
LuFo Lite First Sound - YouTube
Schematic and predicted distortion:
attachment.php
attachment.php
attachment.php
On the bench last night July 27 was a set of custom bifilar wound balanced chokes. Spec was 60mH and 0.5ohm DCR at 10kHz. These are 600w Class EI cores with a 0.1mm airgap. They measured well - identical reactance curves that lie on top of one another. Also checks out at 60mH at 10kHz and gives 160mH at 20Hz. They got a little banged up in shipment but seem to measure and work well. These are for the balanced LuFo 100w single ended Class A amp.
970239d1627417296-susylu-cab5fa9e-38f7-4565-8974-0e4ab003033a-jpeg
970242d1627417939-susylu-custom-lufo-inductor-2-dats-plot-jpg
Listening to it in SE mode (non balanced output):
attachment.php
It sounds very good. The reactance varies smoothly and linearly over the audio range. Whereas the MOT has dips and peaks around 5kHz.
These are heavy suckers:
970241d1627417298-susylu-c0e932ba-23b3-4512-b510-0a0676de8698-jpeg
It is X. I had it laying around for another project but figured I would use it for something better. 😉 I think it should be able to handle the heat. I'm also going to space out the covers just bit with some washers so I can fit the MOT's inside. Should end up looking pretty clean.
