Cheap TPA3118D2 boards, modding them and everything that comes with it
Yes I know what the regulator is for. It's interesting that you consider it "not important". I've been hearing conflicting claims for the last 3 years. Here's what abraxalito said:
I've been listening a while and figure the next 'bottleneck' is most likely the switching reg powering the VDDA rail. Its a LM5010 set to 5V, I figure if I set it to say 7V with a resistor tweak I can put a linear reg between it and the TPA3220.
And JLesterP's SYLPH-D200 TPA3255 board uses a TPS7A49 for GVDD/VDD, instead of the typical LM2940.
The disparity of opinions is stark.
Any idea what these chips actually are? It's a 28-pin SSOP package, and can handle a 21V rail just fine. They sound terrible but I guess that's expected for a fake, remarked chip. These are sold on Amazon (India) for just under $5 each. Interestingly the listing shows the correct PCBs, but this what you get in the package.
I want to reduce gain and/or try PFFB to improve things, as someone who's using a remarked $2 chip will be using inductors below the bottom of the barrell. I soldered the headers and thus can't legitimately ask for a return, but I wasn't expecting fakes so I didn't pay much attention.
Those are TPA3110 chips (or some Asian equivalent).
I had the same issues. Check couple of page back in this topic.
There is a little error in the board, just connect pin 5 and 6 to ground and your board will be nice and quiet! 🙂
(ground should be on pin 3 and 4 if I am not mistaken, but pls double check)
Hi all. I hope you are keeping safe and well and enjoying the run up to the holidays 🙂
I started reading through this thread but it’s reasonably substantial 😛 I’ll apologise to start, because I expect this has been asked and answered at various points in the thread but
I have a Sinilink SY-X100H:
And XH-M567 (actual TPA chip, not the knock off thinner chip):
Which have the expected pop noise on power on/off.
What is the current widely accepted fix for this? I’ve looked through a lot of different suggestions and this one by @DUG:
Seems to be the only one that says it cures the pop when powering off. Is this the go to?
Hi! Today, for the first time, I tried my tpa3118 SANWU boards that I bought some years ago from ebay for perhaps $3 each. They seems both to be completely dead. Upon power up they pulls down the input voltage from 12V -> 2-3V. I measured the power input in it was not shorted, so perhaps there are some short/problem after the diode.
There is no sound at all from the output. No power on thump, hiss or anything. I also tried a 24V led driver that goes into protection directly on power on.
Anyone had this issue?
