Amp Camp Amp - ACA
When doing the DC Balance adjustments is it sufficient to just power the amp, or should there be speakers and/or source connected?
i personally use 2 prepared RCA connectors which are shorted from signal to GND (shield). this helps any amp to have a shorted input and then the noise measurements and setup is much easier.
you can do the same with XLR connectors.
as mooly wrote if you connect a source like DAC or CD player without signal its the same.
chris
I'm thinking about getting the Amp camp amp, so my project is a two way MTM bi amp fully active , so I would need two stereo amps , the woofers are wired to 4ohm 94db sen , and the tweeter is wired to 4ohm 93.5db sen, and it's for a computer setup so I will be sitting very close , will the amp camp amp give me enough power , I don't want rock concert levels but around 80db or so.
Agreed. That shouldn't be a problem. Sounds like a neat setup!
Amp Camp Amp not working.
Hi guys,
Unfortunately my worst nightmare has come true. I have built two amp camp amps. The first one I built works perfectly and sounds fantastic. I’ve just finished the second one and it.s not working. When I set it up as a single stereo amp, I get a faint distorted signal on one side when I turn the volume up high but that’s it.
I guess it’s time to start learning. Can any of you guys help me diagnose the problem? Any help appreciated.
Alex.
Here’s some pics.
@ Alex Jones
Start with the basics.
Check the resistance between the red and black speaker terminals. It should be 500Ω to 1000Ω.
Check the resistance from the outer ring of the RCA inputs to the centre pin. It should be about 50kΩ.
Could you set the 'bias' to 12 volts?
Do both Q1 and Q2 get hot on both channels?
