Maybe good to remain patient and see how things go.
I don't think there is any choice but to be patient and as this is DIY Audio so there are no guarantees, I think that would be generally accepted, however, there's nothing wrong with being enthusiastic and supportive of the efforts of someone who has the ability to work with this sort of stuff and is prepared to share with the community.
I wouldn't have the least clue where to start with this type of project and I can only celebrate the talent of those who do.
+1
+1I don't think there is any choice but to be patient and as this is DIY Audio so there are no guarantees, I think that would be generally accepted, however, there's nothing wrong with being enthusiastic and supportive of the efforts of someone who has the ability to work with this sort of stuff and is prepared to share with the community.
I honestly would just take any that actually works right now.
hi guys
Together with PJotr we have decided to make this project a bit more open.
Soon I will start a new thread where we will put all of the information required to build this modulator.
Great news!
It seems to me that most DIY projects should be free and open. This allows the community to develop the project.
Chapeauhi guys
hi guys
Excellent news, thank you.
hi guys
much appreciated, thank you !! looking forward to it
You really makes me happy!
hi guys
Your decision is really appreciated !!
As I understand FPGA gives the opportunity of firmare upgrades, in the future (alike hqplayer) Moreover RTZ output promise very good quality.
Obviously, the implementation of this "heavy subject" rely to competent developers...
So, thank You olo111 and PJotr. I will follow your thread
THX
For the sake of clarity, it is impossible to run RTZ on a dsc board, different hardware is required...
The shortage of IC AK4137 is still large.
In DSD'it, you can reduce the number and use the TI SRC4121 chip in the first stage.
I'm sure it won't degrade the sound. But for this you have to redo the PCB.
In an experiment, SRC4392 was compared audibly against AK4137. The former would be my 2nd choice, but its quite close in sound to AK4137 for upsmapling. Could be they have a little bit different filter designs, and or they behave a little differently in the presence of low level incoming jitter.
Hello!
Only now I realized the presence of posts regarding FPGA project (by olo111 and PJotr)!
For those that (like me) miss those, here is the link:
Simple DSD modulator for dsc2
Made a DSD'it layout with the first stage on SRC4192.
Sounds a little worse than on two AK4137s.
I noticed that the SRC4192 makes a lot of noise on the ~ 45mV power bus. You need to think carefully about the topology and power supply.
But there is good news as well. Switching DSD<->PCM without clicks.
ASRC ICs reference clock coming in externally over a ribbon cable? Or, maybe no reference clock being used?
- Digital Line Level
- Simple DSD SRC for BeagleBone
