achieve symmetry and get proper grounding. .
When PCB become arts... My next wallpaper
May be it better board ax20:
APEX AX-20 - Share Project - PCBWay
Yes,that really is a great pcb indeed. It is just the fact that i have drawn my pcb such a way that is suitable for my heatsinks,and it has three pairs of output transistors and Power-Signal-Clip indication on it.
But,pcb from your link is really really nice one,no question about that!
I was thinking of a stereo amp for Apex FH-9 xrk mod, still a work in progress to achieve symmetry and get proper grounding. . i have a 90mm x 290mm heaksink salvaged from an onkyo receiver.
this is the one I would really like to have in my possession- good luck with work!
Here are final files and gerbers
Hello, where do you guys buy these mpsa92 ,ksa992,ksc1845, ksc3503, ksa1381 transistors from? Thanks
Always better & better!!!
Bravo Prasi.
Thimios
I did a quick check and they appear to be in stock at Mouser.
I recommended going with an authorized distributor to avoid hours or days of frustration when fake parts blow up and destroy other components when they short.
I have just finished Apex A40 stereo with parts from aliexpress, no problems at 50V. Sounds amazing.
What about delivery to Bosnia for FH9 boards? I would buy 1 board (or 2 if I can't order 1).
This is stereo board, maybe you dont need to buy in pairs?i would buy 3 pairs (6 in total) too.
Looks great! Are they supposed to be cut into two halves (each 50mm x 100mm)? I am thinking about how to mount them on two heat sinks, on either side of the chassis.Here are final files and gerbers
A big kudos to prasi, for all these boards!
Thanks,
these are stereo boards, no need to cut in half.
Simple salvaged MS chassis of an old 5.1 receiver would do perfectly.
I even plan to use the heatsink from the old receiver.
you can even plan for pesante 3U kind of chassis which is cheaper compared to dissipante. Pesante 3U – diyAudio Store
if you have a single heatsink of 100mm height, you can mount it inside the case near the holes/slots for heat dissipation.
Bravo Prasi.
Thimios
Thanks Dr. DIY Amps, 🙂
- 100W Ultimate Fidelity Amplifier
