100W Ultimate Fidelity Amplifier
I was thinking of a stereo amp for Apex FH-9 xrk mod, still a work in progress to achieve symmetry and get proper grounding. . i have a 90mm x 290mm heaksink salvaged from an onkyo receiver.
Here are final files and gerbers
  • GERBERS-APEX FH-9 XRK-MOD-COMPACT-side fet-fh9vx-STEREO-GND_2021-05-01.zip
  • Thank You
Reactions: Elias Zacharopoulos
Thanks,
these are stereo boards, no need to cut in half.
Simple salvaged MS chassis of an old 5.1 receiver would do perfectly.
I even plan to use the heatsink from the old receiver.
you can even plan for pesante 3U kind of chassis which is cheaper compared to dissipante. Pesante 3U – diyAudio Store
if you have a single heatsink of 100mm height, you can mount it inside the case near the holes/slots for heat dissipation.
