MOSFET Amplifier IRFP240/IRFP9240
My contribution for this amplifier.
  • Apex 5532 PCB.pdf
    Apex 5532 PCB.pdf
Reactions: moschfet and 2pist
thats quick Andrew, . meanwhile i made another version. but the one you already made is best.
just remember to use metal film / carbon film for the zobel Resistor, as wirewounds can cause oscillation . just something i learnt recently on Mooly's mosfet amp thread.
regards
prasi
Hi, build this prototype and it works great with + -47vdc, I got 112w (30v at the speaker output) with a consumption of 3.75A
a marvel
9240 and 240
are not complementary, look at the curves.
These are switching devices and its properties are not suitable for linear amplification
You only have to use N Channel Switching Mosfets. Build the same amplifier with just N-Channel IRFP240 and you will hear the difference
Then you will throw the 9240/240 Mosfet amp in the bin
9240 and 240
Hello NMOS, can you suggest any good amp with N-ch mosfets only
clipping indicator not working on simulation
hello guys
I have a little problem with the clipping indicator circuit seem not to work on simulation, does "PRO" need to be connected in order to clipping indicator to work? I'm attaching the multisim 14 file and PDF
I most then making a mistake for sure, but I'm not sure what it is 🙁
Juan
please can you send me the pcb of this power amp ... my email : goldenstars@outlook.fr
