PeeCeeBee Preamplifier GB
Hi Shaan, just finished seting rail voltages, bias and offset, just as you mentioned around 200mV and offset I managed to get it under 1mV, so far I am happy, verry little heat from the mentioned transistors, it doesnt look like they need a heatsink but I do have two small ones so I will add them. Just a quick tip about the documentation regarding the offset, Shaan mentiones how to adjust it only for one chanel the other one requires the procedure also... Shaan correct me if I am wrong.
Thanks,
Florin
Slow...but finally
hoping to finish wiring this weekend. =)
