Measurement data and techniques for Elvee's De-Noizator: all implementations
Would that be an issue with the low output impedance of the regulators? At 20Hz looks like around 2k. I mean for testing to see if the regulator + denoiser is working or not for example.
DSelf Pre Pre has negative input impedance in LF -- so the 220uF cap works fine, but if you want to use a 10uF film cap with very low leakage and low noise, a lot of other values have to change.
When we did the test for the Linear Audio article, noise ranked lowest in terms of importance. But some regulators will mush up transients as the error amplifier is slower than the music!
Input impedance:
As I played with the circuit, trying to get around using a big electrolytic, I observed the same subsonic effect as Scott's 1000x LNA. I stepped the input cap from 2uF to 200uF.
When I was playing around with it I found that as you go higher than 220uF it goes back to having the rising gain, so there is a sweet a sweet spot, I thought 560uF was the sweet spot, but I really don't know enough to verify that.
Playing with the sim I notice that using BC327 instead of 2N4403 the noise goes even lower. Also it seems that using the lower gain version BC327-25 results in even lower noise than with BC327-40.
Would this scale as well for the BC327-16 gain version? There's no spice model for it and I can't simulate.
With 3 transistors the sim shows the noise around the 0.27nV/sqrtHz value.
Found a couple issues:
1. JAVA produces the measurement above, ASIO produces the measurement below, at least on my system.
2. The total noise, in the upper righthand corner, is now lower, I changed the transistors in the dienoiser to BC8*7 and was able to get them stable. I don't think the transistors I had in there before were stable.
I was wondering, would I also need to subtract the ADC noise from the noise measurements I make? Shorting the ADC I get about 0.28nV/√Hz. Of-course this is with the x1000 multiplier, so it's a sort of virtual noise level. The actual noise is 280nV/√Hz, but doesn't it still get added to the LNA+DUT noise?
That puts the LNA around the 0.4nV/sqrtHz in the 10kHz-20kHz area where I looked.
I'm curious to see if I can reliably extract the LNA noise in the LF range where the ADC adds extra noise.
edit: no I can't, the ADC noise is too high to extract any meaningful value.
