Pictures of your diy Pass amplifier
I deal with these machines
😀 for art on living skin
It's only taken me about 7 years since I started this project, but I finally got the heatsink cut down to a slightly less ridiculous size. I may cut it down a little further, or possibly into two smaller individual heat sinks. But at least now I have something manageable to work into an enclosure.
Hmm, is all good but...
It's better to turn the PCBs by 90°, with the fets pointing down and also below the mid point of the heatsink.
That way you'll get a better, much better heat spread.
Also, each channel (either in L/R stereo, balanced mono or parallel mono) draws roughly 1.5Amps, or with 24VDC PSU that is 36Watts.
So your heatsink must handle 72W combined.
I think it might be a bit too small for the task.
