Symmetrical amp clipping behavior - help needed
I tried this - and it looks to me that we just can't place functions referring to param sequences (list) as a SPICE directive.
It must be placed in "Plot Defs File" - right click on the plot -> view -> Plot Defs File.
Add it in there, and save the file.
Then you can add trace with stb() as an expression.
I tried that too - no joy.
Error is 'undefined symbol in <<stb>>()'.
It looks like the .func in the plot.defs is not seen.
If you take my .asc and do this, does it work for you?
BTW I routinely use .param and .step on the schematic screen with no issues.
Which make sense as they are sim directives, nothing to do with plotting results.
Jan
Here is another way to use Tian probe. It also tries to find the gain and phase margins (see View->SPICE Error log).
  • tian.zip
    tian.zip
Minek is right. It won't work as a .func SPICE directive in the .asc schematic. It will give exactly the error you are getting, I think.
I suspect when you add the function in the "Add Trace" it is giving you the right answer. I believe some people keep the function saved in a text file and copy/paste into the "Add Trace" dialog.
I do not know why it is not working as a function in the plot.defs file. Weird.
I have a basic question on the configuration of the probes. I see different setups, looking from the circuit to be measured output to the feedback network.
See attached. All 4 setups give exactly the same result. Which makes sense as the measurement sources are AC so there's no difference in 'polarity'.
Am I right?
Jan
You need to extend the AC analysis to 100MHz. Phase goes to -180 at around 50MHz.
Yes, 100MHz, now it's OK. Thanks for a great tool!
Another issue I found: if I use your method, with the probe subcircuit, the result is an open loop response that drops below 0dB at high frequencies which I guess is realistic.
When I use the method as shown in the attachment, the open loop gain doesn't drop below +27dB, which must be in error.
But I can't find any difference between the two setups.
What am I missing?
Jan
No that doesn't change anything. The .step overrules it anyway, and it is a handy way to exclude the tian stuff when you want to do a .tran or .noise.
I now see that the actual calculation formula between your subcircuit probe and the one I picked up from Russell's post is different. Hmm.
1/(1/(2*(I(Xlp:Vi)@1*V(Xlp:x)@2-V(Xlp:x)@1*I(Xlp:Vi)@2)+V(Xlp:x)@1+I(Xlp:Vi)@2)-1) versus
-1/(1-1/(2*(I(Vi)@1*V(Vend)@2-V(Vend)@1*I(Vi)@2)+V(Vend)@1+I(Vi)@2))
Edit: they both give the same result ...
Jan
I moved both the LoopGainProbe.asc and the .asy in the folder where I have my project.
I can import the .asy as is normally done, and run the sim.
But when I try to plot I get this error:
"Unknown current requested: I(Vi)"
How does that work with the subcircuit, is that automatically 'opened' or parsed, or do I need to point to it explicitly somewhere?
I have checked the Tools menu boxes to save subcircuit voltages and currents.
I tried .include LoopGainProbe.asc on my circuit, but that threw an error "Multiple instances of 'Flag'"...
Jan
