Single Ended Output Tube for Lundahl LL9202 50mA
Lundahl themselves indicate to have a better transformer for a 300B, and they are right.
Using an LL9202 with 6k5 primary load you either have:
1. a 600 ohm primary DC resistance and 100H of primary inductance, or
2. a 150 ohm primary DC resistance and 25H of primary inductance.
Both options are rather sub optimal for a 300B amplifier.
There is a third option to connect the LL9202 to better suit a 300B:
- connect three primaries in series, and connect the fourth primary parallel with one of the three;
- create two strings of secondaries by series connecting four of them, and parallel the two.
Now you have a 3k16 primary load with 8 ohm secondary.
Actually a bit higher primary load because of the highish primary DC resistance which will be a "bad" 375 ohm.
But once more: quite sub optimal....
Andy, I don't think that the WE datasheet is representative for all 300B's.
450V, 50mA, 300B, about 9.5W output.
Lundahl themselves indicate to have a better transformer for a 300B, and they are right...
As I said, I compared LL1664/70 directly with LL1682/50 on a few occasions with my 300b SE and it was no contest - the LL1682 clearly sounded better, and it wasn't subtle. Speakers were Alpair 10M. The LL1682/50 would not be considered an obvious match for a 300b at 5K into 5R. You might even call it "sub optimal" but in practice it works audibly better. I'm not the only 300b user that prefers a 5K OPT, and it's a small step to go a little higher. I was using more like 320v a-k. You don't have to up as high as 450v. Depends on how much power you need. WE data attached. Distortion is low at 350v a-k and 50mA into 5K.
I was using EH 300b tubes. Could be differences between makes - I can't comment on that.
25T? 35T? 811A?
Hey SS - the 25T did come to mind as it is on my short list to build with, another A2 design with NFB. 3.25K 100mA OPT would suit well I think if the transformer is rewired. I have a batch of 25T (3C24) with Eimac grid / plate caps on hand. It biases with a positive grid voltage, had thought I might be able to forgo a negative supply if I choke load a direct-coupled cathode follower for the negative grid swings. Need to generate enough gain on the input for the feedback loop, but with the high mu of the 25T, very little closed loop gain will be needed for a good input sensitivity. Will keep this one in mind, might even try breadboarding it, I have a suitable mains transformer as well.
Just as a reminder, you can always just sell the transformer and go buy something better. Transformers do tend to move pretty quickly in the swap section of the forum. I don't want to dissuade you from building something, but at the same time, you seem to prefer sowter transformers based on your other builds.
If you feel like you must use these in an amp of some kind, I think a type 50 would be pretty much spot on perfect. 6.5K would be a very healthy load, and you might be able to get away with running the type 50s at 55ma on those transformers.
A good type 50 amp might knock your 6A5G amp off it's throne. ; )
Would love to build with the type 50, but the price is intimidating! I was very seriously considering it at one point, even reached out to EML who say they are continuing production of their type 50. But seeing as a type 50 SET is a cost-no-object design already, I think I would want to get dedicated transformers. Will keep it in mind though 😉
Euro21said it right at the start of the thread. Use it at 6.5K with a 300b. It will sound really nice. My daily 300b SE amp has LL1682 50mA OPTs. That's 5K into 5R so quite similar. I have a pair of LL1664/70ma which are 3K and though this might seem a better match on paper it sounds pretty average and nothing like the excellent sound I'm getting from the LL1682. Believe me, I've been there with this one. If you look at the WE data for the 300b, the lowest 3rd harmonic distortion figures are at 5K. I wouldn't hesitate. Drive it with a C3g or something like that and you're good to go.
Another good idea, thanks Andy, my speakers are 92dB/W, so do not need a large power output for my listening space, I am happily running them at 3.75W at the moment, so the higher primary Z with lower distortion and a slight power loss is no problem I think. Will think this over as well, interesting results with your 5K transformer.
N101N,
I find your Post # 27 somewhat mysterious.
So just parallel a 5H or 10H choke in parallel with the 2.5k, 3.5k, or 5k primary.
Lower distortion?
Deeper bass response?
Less hard and thin sound?
How does that work?
Or, just use less Primary turns and less Secondary turns (keep the proper P:S ratio for 2.5k primary).
Lower distortion?
How does that work?
Please explain the theory behind the observations.
2.5K has traditionally been used for good reasons. A smaller primary inductance gives lower distortion, deeper bass response and a less hard and thin sound.
There is no tradition with 300b - anything from 2.5K up to 5K is common. But we're looking at 2 factors when it comes to distortion - the gap and the primary value. For instance Lundahl quote the same inductance for LL1664 at 3K, LL1663 at 5K and LL1682 at 5K into 5R. It's 35H for the 50mA gap and 17H for the 100mA gap. My preference for LL1682/50 over LL1664/70 may be partly due to the higher primary value and partly the higher inductance. And then we have the operating point as another variable, the speaker load as another. In my case the speaker and operating point were the same. My experience with OPTs and plate chokes has been that a higher inductance gives a cleaner sound. With plate chokes, for instance, I've found on two occasions that putting 2 plate chokes in series sounded better than just one. Your ears and taste may be different from mine, of course.
Of course, for those of you who took my post the wrong way . . .
I did not agree with N101N's post # 27 statements.
That is why I gave a couple of non-sensical "solutions".
That is why I asked him to explain what he said.
If the combination of the current through the primary, primary turns, the air gap spacing, and the lamination size are not correct, there will be early saturation of the core.
That causes distortion.
It can also cause the low frequencies to start rolling off at a higher than normal frequency.
As always, the loudspeaker load versus frequency, DCR, pure resistive impedance, and reactive impedance, affects the amplifier performance.
For an example of optimizing the match . . .
Take a look at Eduardo B DeLimas article in Valve magazine (A VSAC and Doc BottleHead publication).
Eduardo, are you still out there?
I make some mistakes in my posts.
I am not perfect.
But when I see a post that might steer someone the wrong way (a newbie or less knowledgeable reader) I often jump in and try and counteract those statements with the correct principals and statements.
andyjevans,
Agreed,
For an SE parafeed amp, putting 2 chokes in series, can improve the low frequency performance.
For my non-sense idea of putting a choke in parallel with the output transformer primary, I meant an SE output transformer that had plate current through it, and now the DC current is divided between the choke and the primary.
So, a primary impedance of 10H in parallel with a 10H choke would make the low frequency roll off 2 times earlier. Not a good idea.
