While they last...
@ Gary S
All Tokin packages pin outs
According to this list (AMPLIMOS V-Fet & SIT Amplifiers, One Stage Amplifiers)
Tonkin devices are N-channel only, designed for industrial applications.
Quoted from the above site:[FONT=Times New Roman, Times]If we thinking about applications for which they are intended, today there may be a subdivision:
[/FONT]
[FONT=Times New Roman, Times] the V-FET were almost exclusively used in the audio gear (low or very low power and frequency) and for this reason they were also manufactured in complementary pairs;
[/FONT]
[FONT=Times New Roman, Times] the SIT instead have been optimized for the industry, for the power electronics and for telecommunication for which there are devices of several KW and / or frequency of GHz. They, however, are manufactured only with one polarity (N channel) and as tubes versions do not exist complementary P-channel: ie unlike Vfet real, SITs were built only in N-channel. Another difference is that it could exist with bipolar charge carriers (BSIT). (Very high current/power)
[/FONT]
A many years ago pioneer DIY projects work was made by Mr. Michael Rothacher
aka AudioMaker | DIY Audio Projects, Etc.
He bring us first Sony Vfet's discovering on the forum and construction articles
and in year 2014 show high power Tokin 2SK180 , SIT modeling software,
how build curve tracer and much more..
VLOG #1: Curve Tracer, Big VFET, SIT Modelling, Ironamp - YouTube
Thanks Sir Rothacher for all fabulous energy and teaching 🙂 Kind regards
You're quite right Soundhappy. Sir Rothacher has done some wonderful work and generously shared it all with us.
Thank you too for your great SIT work!
:cheers:
Is there a chance the design using the larger 2SK182 will have more power output than other versions using lower power rating devices?
What I'm really getting at is can we look forward to a 30+W SIT amp?
I successfully built a prototype 50W SE amp with 182ES with a fan cooled heatsink. Close to 200W dispersion. I'm currently building a final amp on an industrial water cooling plate. Been too busy to finish this amp unfortunately, but I'm sure it can be done with adequate heat management (hard part).
@50W, 4.1A
All SIT 50W+ Single Ended Amp (beta)
I'm wondering if ultra expensive jewelry veblens hi-end have co-opted some of the NP SIT concepts:
Essentia - Aries Cerat
TriodeFet? It would be interesting to see the device they use. Single stage single ended high power TriodeFet? Sounds kinna like a SIT 1 or 2 with a high power SIT and a larger power supply in a fancy package.
