The first 3 - can I ask why ? Already bought USB mic...
VituixCAD works whether measurement data has stable timing reference or not, but accurate result in simulation requires stable (=electrical) timing reference. Dual channel mode requires 2-input sound card and standard mic.
Reading instructions at least once in a lifetime could help. REW version of measurement instructions, page 1:
"Note! Single channel measurement systems such as USB microphones with latency variations by default are not recommended for speaker engineering due to timing and phase variations and normalizations. REW should not be used with single channel connection or mode for far field measurements because timing is normalized by the program. Single channel connection and mode is acceptable for near field measurements only."
Any other way I can use usb mic with Focusrite sound card? Don't think will able to sell it if it's so rubbish... So much misleading info around 🙂
Solo and 2i2 have XLR and jack inputs for standard mics with phantom power. USB mics are connected directly to PC. Problem will be two different USB connectors and separate IO-devices with their buffers which do not maintain constant timing difference so measurement program won't get stable timing reference.
Reading the manual, instructions and skimming through the thread it’s fairly clear that Vituixcad doesn’t do horn designs. As I am building a mass loaded transmission (cylindrical) line I guess it can (from and outside, measuring and designing perspective) be seen as vented box (base reflex) with tweeter, driver and port. The possible choice in Vituixcad will then be number three, base reflex box. But when the port is at the back baffle and not at the front I need to adjust for that. So far I haven’t found the answer myself. Probably not complicated as you know it.
it is doable to get accurate measurements with usb-mics, you only need to manipulate the phase curves. this has been done for ages and it still works, sure it can be a bit tricky
For Chrissake,
Not again this discussion about USB mikes and phase: this is what drives Kimmo out of this thread. The convention here is dual channel measurements with non USB mikes. Period.
Or write a whole new manual in which you may explain all secrets of phase manipulation with USB mikes. That horse has been flogged to death.
Wow, here must one be very careful not to step on any toes
So if your god has spoken we all must follow or what? Yikes
I'll bite.
How do you get accurate dual channel measurements with a single channel USB mic?
Or can you explain, "it is doable to get accurate measurements with usb-mics, you only need to manipulate the phase curves. this has been done for ages and it still works, sure it can be a bit tricky"
So we can put this to rest and simply tell people to stop trying to use USB mics with VituixCAD and use a proper dual channel set up.
the method has been told and showed many times before by others, i really do not need to repeat it
Are you talking about sum method giving difference between acoustic centers as a distance or delay?
This thread from now on should be declared an official USB Mic Free Two Channel Measurement Zone. (UMFTMZ) in order not to distract from or sidetrack of VCad related discussions.
Diya is full of places where USB mic minded can seek refuge.
I figured it out why Americans like and use USB mic's!
The same reason they like Fast Food, both are cheap and quick, just not very good for you... 🙂
Joined 2003
USB mics have their place with room EQ and measurement of completed speakers, you don't have to throw them out 🙂. For design, 2 channel system is far superior.
🙂 So many interesting eyeopening things happened with me after spending 2 hours reading the manual 🙂 The next question is what's better BMW or Audi? Ups, not here, sorry. What mic to buy?
Joined 2003
Power response aside, That first crossover is really pushing that tweeter, I'd go with the 2nd order crossover strictly from a distortion standpoint.
...Vituixcad doesn’t horn designs...
But when the port is at the back baffle and not at the front I need adjust for that.
That's right. You can't design/simulate horns, wave guides, resistance enclosures, transmission lines and OB TLs etc. Those should be designed with capable tool, then built actual radiator+cabinet, measured, and data loaded to main program which supports everything. There will always be radiator types which are not yet invented, but main program should and will support them.
Merger tool is simplified at the moment so that all LF radiators use the same baffle effect response. Directivity at LF is based on far field measurements so rear port signal will be strongest to back also in merged responses.
- Design & Build
- Software Tools
- VituixCAD
