Same. I set the probe and the scope to 10X. With power same 152mV Vrms ripple, when I turned it off 1mV rms noise. almost nothing
Is it 100 Ohm loaded also? What is the DC voltage between pins of R1 now?
Yes loaded 100Ohm. DC voltage between the leg of R1 is 0.6V
With more probe bandwidth it should have gone stronger. Anyway. We will see about that. Is it standalone testing or in a box with other things powered up?
It is standalone. On my desktop. Not in box at all.
Attach cable like that on the output and solder the 100 Ohm dummy at the cable's free ends. Probe on the 100 Ohm.
Do you have any other make and type C3?
I have 22uF AudioNote; 22uF Nichicon UFG; 100uF UFG 10 uF UKZ; 68uF Pana FC
At the end it's working very well. No measurable noise, stable output voltage. I appreciate your help, and effort during this troubleshooting. Thanks
I bought from a small store 25pcs.
Genuine I hope. Physical store?
You are welcome. In the end dac installation you mean? Or you changed some part?
- Power Supplies
- Salas SSLV1.3 UltraBiB shunt regulator
