Acoustic Horn Design – The Easy Way (Ath4)
BTW, one question arise
what is benefit of flat wavefront in simulation.'?
I have no any clue what is shape of wavefront after phase plug of CD but seems very unlikely to be flat. As I know most of CD's have concave or convex membrane which moving axially so wouldn't axially moving spherical cap be most similar?
5. TD-2001 & HF10AK on RCF H3709...
The RCF H3709 is a straight throat clone of the Altec/WE 32 series.
The latter has been printed with another binder jetting 3D printing technology called AMClad, which is (also) sand-based.
Picture no. 4 shows the original on top of the printed horn.
The intent of virtually all phase plugs is a flat equ-phase wavefront at the exit aperture. How well it is achieved is complicated to the point that I have never seen it measured.
that insert seems like really good idea. It will be very easy to make it on lathe machine (and probably more precise than 3D printing).
It will make entry angle 0 for all CDs where is applicable so, as I understand, naturally better for the flat wavefront.
To not squeeze the exit to much maybe will be the best to take 1.4" CD and implement such insert
Looks a bit rough with 1mm nozzle. Is this to be expected or can I do way better with this size nozzle? Hopefully it's good enough for testing purposes.
Step 1: if you're using PETG, blast the print with a propane torch, to smooth everything out
Step 2: Use some filler to get a glass finish
Attached is a pic of my latest print. This uses VERY limited sanding. I basically spent ten minutes covering it in that stuff you use to patch drywall, and then ten minutes sanding it.
With some effort, you can get a perfectly smooth finish.
Aren't many CD made with a "front piece" that can be removed and the diaphragm exposed as in the picture?
Do you mean that one cant buy them as such and it implies that one has to throw away a piece of metal? Or what kind of engagement from manufacturers did you have in mind?
