If we were all honest, we'd recognize the digital design is the future. But most of use take more pleasure in analog design, components you can solder, and the physical side of acoustics.
Am I speaking just for myself?
BTW, my audio life has been immensely enhanced since getting a Behringer DCX2496 DSP (like $180, but takes 2 yrs to get good at setting it). How did I get along without one before?
Ben - hope to see all when this epidemic is over
Joined 2009
@mikett
Nice stuff.
Could you detail the construction of your DC power cables -- the twisted pairs -- and connectors please?
The connectors are aviation type connectors that I purchased on Ebay. They are very reasonably priced there.
The twisted cables I fabricated using PVC stranded wire hookup cable. The trick is to secure the wires in a variable speed drill. Hold them out in a straight line and then have the drill slowly turn. You then need to use a hand that holds the wires that must be kept separate and you hand must stay close to the twist point and also allow the wire to slip through your fingers as the twisting progresses. If you need to make more than 2 feet then a second person might be necessary. For short runs, I operate the drill with my left hand and I control the twist with my right hand. To keep the twist even, the tension must be kept constant and the more tension, the tighter the twist. For large gauges, a leather glove will help prevent skin burn.
If we had a meet, I could demonstrate the process. It's best that way.
I'm currently using a modded Assemblage DAC 3.1, have a jitterbug somewhere in the basement.
Next DAC will likely be Twistedpair ESS 9028/9038
I looked at a twisted pear when I burned out my first DAC board. ( My hand slipped with a probe and AVCC got 12V instaed of 3.3V) and instant smoke, CMOS construction)
Then I started to add up what a Twisted Pear would cost in the end when I would finish and it was not too far off what a Benchmark DAC3 would run and with the Benchmark, the resale value is very high. Whereas with DIY stuff, not that much. So my theory at the time was that the taxes on the Benchmark = cost of DIY DAC or so I thought. Was not to be the case.
The other thing is the amount of work for the chassis in the case. I needed a ready made case and I was able to obtain a DAC case premachined as well as the identical case with no machining for the power supplies. That was a significant factor for me.
@mikett Thanks.
That's a technique reminiscent of one I read in a TAA letter about making pseudo litz cables by twisting. A lot of work to get a tighter twist!
Is the objective to get more turns per inch or to keep the wires close together along their length... or both?
Insulation thickness might be consideration in either case.
Got enough light in there? I spot another 1000Watt or something workling on the left side.
Don't laugh, as you get older those things become invaluable. I'm down that hole right now. Soldering can be a bit challenging nowadays especially with the SMD stuff.
LOL the one that is on is 30W, the one that is off is 100W (and it flickers at 60Hz - Annoying!) and the yellow one is a 500W halogen that needs a bulb and has basically been retired.
Re Ferrite clamp
IMHO, Ferrite clamps make a difference but to my ear not always a good difference. If I put them on a power cord as often recommended, I find it slightly kills the reproduction of low level information.
Where I use them to advantage is on the safety ground of power cables closest to the consumer. Surprisingly, I find they add to the clarity and low bass. I believe it may reduce RF/EMI on the ground plane but am only speculating.
@mikett Thanks.
For me it makes the wires more manageable and I don't have to go out and purchase more cables actually. Yes, they say that it makes the runs more immune to pickup. Probably true but it also neatens up a lot of things. I got the wire in the early 80s when it was discarded by someone who no longer had need for it. I've had it since and I find uses for it here and there. So it uses bespoke wire from the 80s. Wired with 40 year old stock copper that has been carefully aged like vintage wine.
Mike,
Looked like you have been real busy. You have to bring your new toys to the next meet.
After going through the reviews of some of those small commercially available DACs came out of China at AudioSciencereview.com, I decided that there is really no point for me to even try to assemble a DAC. For a few hundred dollars, the performance one can get is amazing. Everything is properly done (PCB layout, multiple stages of ultra low noise regulated power supplies, top of the line ESS DAC chip, CNC milled aluminum case etc.) and many of them come with a headphone amp and can be used as a preamp.
I am planning to build a pair of small full range speakers (5" driver) from a kit. Unfortunately, the COVID-19 situation is really impeding the transportation of all the parts needed, which are actually sitting in HK waiting for me to pick up. The original plan was that I would fly back for vacation and bring them with me when I return. With the pandemic, don't know when can I take the trip. Shipping is expensive and I rather used the money to cover part of the plane ticket cost. Hopefully, I can bring the speakers to show you folks in the next meet (sometime next year I hope).
I can't wait to see what everyone has been building!
I promise to bring my F5T, so long as I can get some help lifting it out of the trunk. It lives on a wheeled cart now.....
I've also modified the DCB1 buffer some of you may have already heard..... it's got an XLR input courtesy of a neurochrome buffer board instead of the plain single ended one. That board is totally transparent as far as I can tell...
And it may be using the ALLO stepped volume control ( I hope it works well ) -- or a DACT/Khozmo if it does not. The Allo should arrive in a week or so.
Also, with luck, the AKSA lender preamp will be built, which can push 40 V -- that is in preparation for an F4 build.
Have any of you compared the DACT with the Khozmo Ladder?
Mike,
Absolutely correct! I was only half way through building the DAC and there was always more work to do. I got frustrated and decided to shelve everything and ordered what was possibly exactly what you had looked at AudioScience Review.
The Topping D90. Based on specs and physically what was received, it was a no brainer, so I got one.
Then I listened to what I had "in development" and compared back and forth. I've seen comments that what measures well does not always sound good. There was a problem with female vocals on the sample of the D90 relative to what I had in development. I was not totally satisfied. It clearly was better than what I had in development and by all accounts very good but the problem with female vocals especially voices like Stacey Kent was bothersome. That put a fire on my rear to finish the DAC I was halfway through for about 2 years. Things took a real backward step when I burned up an expensive LTC6655 when I made a power supply and interchanged + and - on powerup. I was so pissed. I just sat on it. Then I discovered Jung's GLED and that combined with the SuperReg with the remote sense did it for me. I am still sitting on the Zetex transistor and LT6200 which has about 1/10 the noise and massive bandwidth.
Also the D90 does not convey weight of the bottom octave I discovered.
If you're not into building a tweaked machine, then something like the D90 is perfect. No Doubt. However, my belief is that something like a twisted pear and tweaked support circuits can outdo the machines like Topping BUT you're not saving money nor will it be inexpensive, you'll have lot of left over circuits and it will take a lot of time....lots of negatives. If I had not started earlier when things like the D90 was not around I probably would not have started. The days of DIY are numbered by the chinese hif products.
I am glad to hear that the Neurochrome buffer sounds good. That had been on my radar. Tom C. knows what he is doing. I really wish him well and hope his venture works out.
I know this might not be the place for it, but I want to sell an amp I built, but only to local GTA people.
It's a Williamson KT88 UL design using Hammond iron including 278CX PT, 1650N OPT, 193Q choke, 155J chokes on the preamp stage, and DC for the first tube heaters. Also one touch power instead of a toggle switch.
Circuit design is 100W, OPTs are 60W. Cathode biased using Dale resistors and 22000 hour 105C caps. All caps are 105C and long life. KT88 tubes are unmarked Chinese. VA/PI is provided by 6F12P. Driver is RCA 6SN7 "Black Plate" Oooh! LMAO
Feel free to come hear it in midtown Toronto.
$1500 takes it.
I'll provide a schematic and warranty if you don't just want it for parts...
Also looking for someone interested in auditioning an RIAA stage.
$1500 takes it.
New Year again guys, I had hoped it would be a better one than last and we could finally have another meet. Well I hope everyone gets a better one.
Not sure about that anymore. The Vax rollout is way too slow to be possibly a good thing. Yesterday the announcement of 1 million a week starting April sounded impressive. Except in December I threw the scenario in Excel and only half the population stands to be properly vaxed by next Christmas. Well...now here comes the three mutants already which complicates things more. Good thing I know some math and modeling.
So I was going to be holed up another year. Threw in the towel and got a Benchmark AHB2 and LA4. I'm not going anywhere and this thing is going to be at least 2 years before I enjoy myself so I'll do that at home. BTW, that Benchmark Media stuff is amazing and I don't normally say that. Transformative and not subtle at all.
Happy New Year guys!
Joined 2009
Happy New Year to all as well.So I was going to be holed up another year. Threw in the towel and got a Benchmark AHB2 and LA4. I'm not going anywhere and this thing is going to be at least 2 years before I enjoy myself so I'll do that at home. BTW, that Benchmark Media stuff is amazing and I don't normally say that. Transformative and not subtle at all.
Sounds like you are going to be having some great sound with the help of Benchmark. What speakers are you using with them? They are compact enough that you could bring them to an audio meet in the future?
Early on I expected to be isolated until Sept of this year, so if anything I think I'll be pleasantly surprised. If I recall, our host was waiting for a hip replacement. That may have been delayed in 2020. If so best of luck getting it scheduled.
I'm pretty happy with the sound system. About the only project planned is to implement Andrea Mori's final 5mHz clock to replace his already very good 45mHz WTMC. Otherwise the next thing will be a little room treatment. Maybe some subs to get the low registers filled in.
Well it I think the Fed official that made the announcement yesterday is based on two approved ones. Despite that, when the reality of ramping up is accounted, I don't think the modelling is far off. The issue of the mutations is not taken account in those numbers.
Just saw in CP24, Biden goal is 100 million vaccines by the first 100 days. Sounds great right? It fools the masses. Well it is 7 times Canada's which is exceptional. Except......1. The USA needs 10 times what we target 2. that the USA needs with the proven vaccines....2 shots per head about 800 million shots including the undocumented ( including our snowbirds!). If Biden's target was maintained, then they would need 800 days! ( 365 days per year)
Yes, at 50% coverage some semblance of herd immunity starts to appear slightly but it would still place a lot of restrictions on the table. For one the death rate statistic would come down significantly as the most prone demographic would be covered. I'm crossing my fingers but I am not packing up for a vacation!
- Member Areas
- Clubs & Events
- Greater Toronto Area DIY meetup
