Da-capo issue (John W?)
Anyone tried any modern word clock compatible usb-spdif yet?
We have Mtech evo converter which is compatible with a 128fs clock.
Newly added Mutec MC3+ USB which looks like it will also accept a 128fs word clock.
This means we potentially have two devices we can feed the clock lock cards clock and feed the spdif signal back into the digital in for a clock locked async usb replay.
Hello gentlemen,
Can't help to show off a bit: did you know there was a special limited edition of Ordinal with a USB input? 😀
https://postimg.cc/Tpw9knQ9
Well, I'm not sure JW has ever heard about this version, but I got it now... After months of struggle with the faulty left channel (post #795), I finally found a capable technician who found the problem in a couple of hours. All caps were replaced with long-life Rubicons, I liked the sound a lot - but had not much use for the Ordinal, since 95% of my digital music is on a server, not on CDs.
So the Ordinal got a brand new XMOS board - i2soverusb by a local company named JL Sounds. The same board is used by quite a few high-end brands (Thrax Audio for sure, can't name the others). It's connected in parallel to the existing S/PDIF input. The tech managed to squeeze in a separate power supply (powering this board over USB is not a great idea, I've heard that before) - and the results are fantastic.
https://postimg.cc/ykbT2Wbz
https://postimg.cc/Z0jHFwPn
In terms of musicality, the old Brit outplayed my other DAC - custom full dual-mono configuration with Delta-Sigma Asahi Kasei DAC chips, precision oscillators, three toroidal transfomers and the same XMOS board - straight away. Of course, in a side-by-side comparison the sound of the Ordinal is much rougher, and the level of detail from a hi-res file is unobtainable with the old technology - but the scene is tighter and better laid out for sheer listening pleasure.
I'm not so technically savvy myself to explain all the details, but could ask the technician, if there are any specific questions.
Been using the xmos board myself externally but hope to try either m2tech evo converter or the mc3+ usb thing feeding my clock lock card instead.
If John W pops in after reading your review about the clock in the Da-Capo and the discrete 1 bit be so sensitive to quality of clock and you ending up designing a rather large clock and clock cleaner circuit for a relatively simple DAC. Can you actually remember how accurate you eventually got the clock in the Da-Capo.
About to get last bit to set up my music ripper server/streaming system that will be clock locked to da-capo.
Still canny decide between Logitech Transporter (which handles 128fs clock input) and m2tech evo2 usb-spdif which will also handle a 128fs clock input. So both should be compatible with the clock lock input cards designed for cardinal.
John
I’d happily make some mods to improve it.... know the output stage can be improved too but probs beyond me.
Glad I still have a running one. And really looking forward to trying with clock locked streaming/flac server. According to transporter designer his digital out when synced to a clock should be about 4ppm with incoming clock which I should imagine is superb for the da-capo.
Here is a question. Someone who worked at PT reckons PT managed to make the da-capo with one of caps under dac metal can the wrong way round. Did they actually do this? And if yes what did it do and would correcting it help any?
Designer reckoned in his testing when fed a clock the data should come out to dac with accuracy to clock fed in of 4ppm which should allow da-capo to perform at its very best. Really like fact transporter was made with proper BNC connectors on digital in, out and word clock input 🙂
Mr MAC,
If you can confirm the transporter supports 128 CLK input - also once clocklocked, then you can only playback 44.1KHz files (CD rips etc).
buy cutting track sunder the potted module and injecting the clock then you can bypass the DAC's PLL based clock - driven directly by the Crystal on the Clock lock DIC...
WRT the reversed Cap under the potted DAC section, I'm not aware of this, but this might have occurred after I left PT - it would explain a later Dacapo board (built after i left) I have here that failed under the potted section... It could be a Tant cap reversed in the PLL Loop BW filter...
Dacapo can’t do much more than 44.1 anyway 🙂
That is also fine as iirc LMS can transcode on fly if fed with something higher anyway.
Hmmm need to know more about the mod and what I gain and loose by doing it 🙂 assume mod will mean clock lock only and loose spdif cards? Or could mode be made switchable? Hmmm may need a 2nd da-capo to compare how mod sounds.
Many thanks 🙂
Yep appears transporter and m2tech evo2 usb-spdif are only two ways to clock lock da-capo to a streamer/music server type setup as they are only two I can find that will take a 128fs word clock.
Will also compare spdif non-clock locked and the transporters own dac via its balanced outputs and see how each performs and what wins out as best performer.
Anyone know the dimension or model of batteries for the DC before I order some. Just to save me dragging it out to put away again till get cells and transporter here.
My current dc has all batteries half width and all same voltage cells (my earlier DC had mix of larger double the voltage ones and half width ones).
Dacapo can’t do much more than 44.1 anyway 🙂 sure you said in this thread the spec sheet was wrong and da-capo wouldn’t handle 48khz (or was that just meant to be the clock lock)
Many thanks 🙂
What batteries should be in the DC????
My old on had a larger and smaller battery in 4 banks??? (Just a guess) 1 larger and 1 smaller so guessing 12v and 6v making 18v. I have also seen same arrangement but using 3x 6v cells. Tonight I am seeing what looks like all 12v cells (or are they just large 6v ones?) yeah must be bigger 6v ones and sure my current one is using 3v cells so 6 per 18v bank.
See the three photos. I take it it’s just a case of what will fit in case and maybe people maximising capacity fitting larger cells.
Hi Mr mac,
So you want 18V per Bank - and the largest cells you can find that will fit the case.
I believe (from feedback that came to me) the original Cell size is no longer available - the cells used in the last unit pictured is a great solution if the are 6V cells...
WRT to the German unit - I have no idea whats going on here, you can see the same type caps have also leaked on the DC input card - and the caps in the Digital section, so these should also have been replaced...
If you wanted a donor unit then I could repair and update this unit with Clock lock card - it has the HDCD filter which IMO is the best.
I'm also JUST working on a FPGA solution for the never ending FDAC / MDACII project, parts of this "IP" could be tested on a modulator board for the Dacapo.
