Xmas Amp - Dibya's TDA7293 by Jhofland
Hi Kay,
All fake chip i got have V6 written on it, They will fly to sky like a fire cracker when you use more than ±25V DC.
It seems V6 chips from mouser are free from firecracker syndrome.
Hi Vunce,
How it sounds? Please can i know your subjective perspective. Did you try any preamp?
Founder of XSA-Labs
Joined 2012
Hi Vunce,
That TO-264 ceramic insulator seems like it was made for this! Nice build! When will you be in stereo?
907065d1609529978-xmas-amp-dibyas-tda7293-jhofland-image-jpg
Joined 2014
Second channel hot off the press!!
I’ll have time to fire it up now, check offset, and pass the magic smoke test :D. I believe tomorrow I will have full stereo enjoyment. I think I have a “doner” chassis I can use ;)
I know, my inductors look sad. I didn’t have enough magnetic wire on hand, so I unwound a pair of inductors I had in my parts bin and rewound them for this application.
Thanks for the link Vunce.
Instead of using a screw + screw insulation going through the IC, I normally use these clip + some insulation between the IC and the heatsink. It’s much easier if you have the room for it on the heatsink. It’s from AAVID, model Max08Blocked
BR
Eric
Founder of XSA-Labs
Joined 2012
Hi X
Is this nice project similar to that group buy?
Folsom EC7293: PVI Powered Frontend, 60/120w 8/4ohm
Fab
Hi Fab,
The project by Folsom (Destroyer_OS) is very different in that there is a discrete 4 transistor front end that performs error correction. Destroyer_OS did not publish a schematic, so I can't say what it looks like. But Dibya's amp is much more straightforward - we are not using anything other than the TDA7293 chipamp to perform the amplification with its own intrisnic feedback and gain.
But thanks for pointing out that he also uses a TDA7293.
